2016 S3 2nd to 1st gear hiccup
Hi Everyone;
I have a 2016 S3 S-Tronic and whenever I'm coming to a full stop and gear is changing from 2nd to 1st (automatically in "D" mode), the cur hiccups pretty harsh! The whole car slightly (8-10%) shakes and you can hear the car is struggling with changing the gear. I pretty much had this problem for a year or so and always thought it is normal (I never owned an automatic car before).
It's like you have a manual car and forget to change the gear from 3rd or 2nd to 1st gear when coming to a stop. Is this a normal issue or should I take it to the dealer as it is still under warranty?
Thanks in Advance
Thanks in Advance
So I took the car to the dealership and they reset the systems for the gearbox and the problem was better for 1-2 weeks. Then after that the problem came back on and I took it to the dealership again.
After 2 days, they said they've drained the gearbox fluid and found some metal debris there which they do not know where are they coming from! So initially they just wanted to just put new fluid back and give me the car but Audi Canada told them that they have to change the whole transmission in my vehicle. So I'm looking for at least 1 week wait time with a Q5 loaner car (not bad) and the whole thing costs around $10,000, which is covered under warranty.
To put things in perspective, that is about the same cost of depreciation on the first year of owning a new Audi. So, why would it scare you to own it pass warranty? You pay for it one way or another.
Hi, in ERWIN I found a TSB for A3 8V with those syntoms. Maybe it could help TSB. 2027884/16 it is in spanish but it explains that the delaer have to make some software update for DSG and also change the flying wheel. Let you in spanish, try translating in google please:
"Información técnica de producto Artículo nº: 2027884/16
Vibraciones/Tirones/Retemblados al cambiar de 1ª a 2ª con el cambio
0AM/0CW
Fecha de publicación: 13-nov-
2017
Exposición del cliente / comprobación del taller
La reclamación consiste en vibraciones/tirones/retemblados breves (1-2 segundos).
- al conmutar de 1ª a 2ª o
- al conmutar de 2ª a 1ª o
- al acelerar en 2ª (circulando por ciudad) o
- al arrancar hacia adelante o hacia atrás
Comprobación del taller: La reclamación del cliente es reproducible y la causa puede atribuirse al
cambio.
Antecedentes técnicos
Implementación de un forro optimizado del embrague múltiple.
Implementación en la serie
Medida
Intentar reproducir la reclamación del cliente (de acuerdo con la exposición del cliente) para
establecer una correspondencia exacta con esta información técnica de producto.
Las entradas de la memoria de incidencias en todas las unidades de control deberán haberse
procesado antes de proceder con otros pasos.
Se deberá descartar la existencia de otra medida (TPI/componentes/software, etc.) que resuelva esta
reclamación. En caso contrario, se producirá una nueva reparación. En este caso el fabricante se
reserva el derecho a rechazar la liquidación en garantía y a regularizar las piezas desmontadas.
Realizar un ajuste básico del cambio mediante las funciones guiadas. Acto seguido, durante el
recorrido de prueba se deberá comprobar si puede seguir reproduciéndose la reclamación. Para ello es
indispensable que en el informe de diagnosis se haya confirmado que el ajuste básico del cambio se ha
realizado correctamente.
Si se puede seguir reproduciendo la reclamación de cliente:
1. Sustituir el embrague múltiple (juego de reparación de servicio de posventa)
2. En caso necesario, se deberá realizar otra actualización del software de la unidad de control del
cambio.
Modelo de vehículo Año de modelos Código SVM Versión de software
Información técnica de producto 2027884/16 Page 1 of 3
https://erwin.audi.com/erwin/rp/elsa...77716/master.x... 23/02/2018
8J MY 12-14 02A077 igual/posterior a 52XX
8P MY 09-11 02A077 igual/posterior 90xx
8P MY 12-13 02A077 igual/posterior a 52XX
8V MY 13-15 02A080 igual/posterior a 52XX
8X MY 11 02A080 igual/posterior 90xx
8X MY 12-15 02A080 igual/posterior a 52XX
Nota: En el MY16 se produjo un cambio a la 2ª generación de la unidad mecatrónica en el modelo de
vehículo 8V durante el año de modelos (semana 45/15). Es decir, si un vehículo tiene la versión de
software 06xx hasta 09xx, no será necesaria una actualización del software.
Por ejemplo:
0CW300045N 4530 => Actualización necesaria
0CW300046A 5115 => Actualización necesaria
0AM300053A 3010 => Actualización necesaria
0CW300040H 0605 => 2ª generación o es necesaria una actualización
0CW300045M 5240 => cumple con el criterio como mínimo 52xx no es necesaria una actualización
0AM300063G6201 => cumple con el criterio como mínimo 52xx no es necesaria una actualización
La actualización de software garantiza el correcto funcionamiento del embrague múltiple.
La causa de la reclamación no es el volante de inercia bimasa.
Es posible que la unidad de control del cambio ya tenga la versión de software actual a causa de una
actualización previa del software. En este caso no se requerirán más actualizaciones de software.
Indicaciones para la liquidación
AT n.º/Avería 3060 / 0010
Liquidación en APOS:
Modelo: Posición de trabajo: Denominación: Unidades de tiempo:
Todos 343519xx Desmontar y montar
cambio
Utilizar especificación
según APOS
Todos 3060195x Desmontar y montar
embrague múltiple
según APOS
Todos 3060555x Sustituir embrague
múltiple
según APOS
01500000 LGA/Función guiada
Información técnica de producto 2027884/16 Page 2 of 3
Sin actualización de
software
UT según informe de
diagnosis
Con actualización de
software
01510000 Actualización de software UT según informe de
diagnosis
Todos 27068950 Cargar batería Utilizar especificación
según APOS
Tener en cuenta las posiciones Anterior, Incluye y Sin indicadas en las posiciones de trabajo.
Liquidación en APOSpro:
Modelo:
Ilustración:Posición:
Número de
bastidor: Denominación: Trabajos:
Unidades de
tiempo:
Todos 300-05x 1 3000xx Cambio 19 Según
especificaciones
Todos 141-xxx 1 198140 Embrague
múltiple
55 Según
especificaciones
Sin
actualización
de software
STA-002 1 S00032 Localización
guiada de averías
A8 UT según informe
de diagnosis
Con
actualización
de software
STA-002 1 S00042 Actualización de
software
A8 UT según informe
de diagnosis
Todos STA-002 4 915105 Batería 89 Según
especificaciones
0AM/0CW
2017
cambio.
Medida
cambio.
Por ejemplo:
cambio
según APOS
embrague múltiple
según APOS
múltiple
según APOS
software
UT según informe de
diagnosis
software
diagnosis
según APOS
Modelo:
Número de
Unidades de
tiempo:
especificaciones
múltiple
55 Según
especificaciones
Sin
actualización
de software
guiada de averías
A8 UT según informe
de diagnosis
Con
actualización
de software
software
A8 UT según informe
de diagnosis
especificaciones
i can drive a car that depreciated. i cant drive a car that needs a new $10k transmission.
Not sure I understand your logic - You can't drive a car that needs a new $10k transmission regardless (whether it's under factory warranty or not). Driving a car that has factory warranty doesn't guarantee that your transmission won't fail.
i am afraid to own the s3 after warranty because if the transmission fails, i dont want to spend $10k to replace. If the transmission fails while i am under warranty, then i wont have to pay the $10k to fix it. what do you not get?
simply put:
i guess i dont see how depreciation factors into me not wanting to pay $10k for a dsg transmission if it fails when the car is not under warranty anymore.
simply put:
- im NOT afraid to own the s3 while under warranty because the if the transmission fails (while under warranty), then it would get replaced under warranty with no out of pocket cost to me.
- i AM afraid to own the s3 when it is NOT under warranty anymore because if the transmission fails (while not under warranty), then i would have to pay $10k to fix it. what does any of this have to do with deprecation?
