Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
2015 S3 new front Rotors and pads needed at 42,000 miles?
Old 11-06-2019, 12:03 PM
MacSound's Avatar
Default 2015 S3 new front Rotors and pads needed at 42,000 miles?
In for an oil change and my mechanic for 10 years who I have always trusted says my rotors are worn more than my pads? I have never heard that before.
Cost with oil change is 575.00 cash. My brake sensor did not go on and my brakes feel fine although maybe not as well as when I fist got the car with 35,000 miles on it.
Just wondered what other S3 folks experience is with front brake pad and rotor wear. I drive pretty hard, have know idea how the other two owners drove it.
The dealership by me didn't say I needed them when they did a full inspection when I bought the car or when I brought it in for inspection a few weeks ago so I find it odd.
Old 11-06-2019, 04:18 PM
morris39's Avatar
Just changed to winter tires and measured wear on disks and pads on my S3 with 31 k miles. Front disks worn 33% of allowable (1.0 /3.0 mm) , rear disks worn 25% (0.5 /2.0 mm ) of allowable. Both front and rear disks not grooved/damaged although there are very discernible "lips", which is normal.
Pads are about 50% worn which is typical for my previous cars. The car is lightly loaded and exercised about 5-10% of the time on local mountain roads, the rest of the time it runs with the herd in small city suburban traffic.
MacSound (11-06-2019)
Old 11-06-2019, 05:31 PM
MacSound's Avatar
Thanks I went ahead with it, may be a bit premature but I trust my guy, he said the pads had been replaced once before but not the rotors hence why the rotors were more worn, I did not ask him for rotor measurements. I drive down the west side highway in Manhattan so stopping is very important
Old 11-12-2019, 01:03 PM
extrememike's Avatar
I've got 52K miles on my S3. Still original rotors and brake pads.
Not sure about the rotors but the pads were at 6 mm in the front and 5 mm on the back. That was 2 mos ago before I went to stage 2.
Planning to replace next year.
Old 11-12-2019, 02:20 PM
MacSound's Avatar
Cool, you can then upgrade your brake package now that you went stage two.
How do you like stage 2? Did you go with APR or someone else? I am hoping to do that next spring with my guy who recommends United Motor Sport ECU http://unitedmotorsport.net/products...productId=1381
Old 11-12-2019, 08:47 PM
morris39's Avatar
Upgrade? Why? He got 52k miles so far from the pads and likely 60k or more by the time he is ready to replace them. The OEM pads have a really nice linear/progressive feel.
Old 11-13-2019, 07:03 AM
Agree. OEM works fine. I don't see a need to upgrade unless you are planning to track the car. More than likely replace rotors IF needed and pads.
On the Tune I went with APR. I had stage 1 for over a year. Stage 2 gives you additional Torque and some marginal power but I dint't noticed much as I did when I went from stock to Stage 1. Stage 2 enhances the exhaust note beautifully.
Old 11-19-2019, 10:53 AM
MacSound's Avatar
Ok good to know thanks, I figured some folks do track there cars when going to a stage 2 but not necessarily.
S5TIG
17
12-15-2018 02:46 AM
dfwdfw
Q5/SQ5 MKI (8R) Discussion
13
01-04-2017 10:41 PM
Dalancroft
03-22-2015 02:44 PM
pl599
Q7 MK 1 Discussion
04-07-2011 08:25 AM
mesadler
03-21-2004 06:45 AM
Quick Reply: 2015 S3 new front Rotors and pads needed at 42,000 miles?
