Audi 2015 A3 Quattro
HI All.
Was hoping for some thoughts. APR Stage 2, DownPipe, ECU and Trans Tune, Liquid Moly and Spark Plugs changed for APR tune. This car was a sleeper all tinted out and smooth. Well... All of a sudden while driving normally, the Audi downshifted to 2 gear, sadi it was safe to drive but would not come out of 2nd gear. Ran trouble codes and this is what I get: P0732 - Gear 2 incorrect ratio P074A - Unable to engage gear 2 Synchniz aborted 10731 - Valve 2 in tran Part 1 10732 - Valve 3 in tran part 2 10657 - RPM Signal From ECU 10909 - Cooling Oil Valve 10906 - Cooling Oil Valve 10763 - Starter Enable From Selector Level Sensor System 21148,21153,21154,21155,21157,21159,21207,21181,17 178 Replaced Mech and all gaskets, Fluids and filters (Clean output), Car has had every service and no trans issues in the past. 51K miles (Yeah just out of warranty) Any Suggestions? (Enter SMH Icon here) |
Well Well
After putting a full charge to the Battery, can clearing al the codes. I have these now (only).OBDeleven data log
Date: 2019-01-08/9 20:03 VIN: WAUBFGFF5F1008851 Car: Audi A3 Year: 2015 Body type: Saloon Engine: CNTC 162 kW (220 HP) 2.0 l Mileage: 83350 KM--------------------------------------------------------------- 01 Engine System description: 2.0l R4 TFSI Software number: 5G0906259A Software version: 0002 Hardware number: 06K907425B Hardware version: H13 ODX name: EV_ECM20TFS0205G0906259A ODX version: 001004 Long coding: 0A1D00124426000F2000 Trouble codes: P157000 - Engine Control Module (ECM) disabled static--------------------------------------------------------------- 02 Transmission System description: DQ250-6A MQB Software number: 0D9300012K Software version: 4515 Hardware number: 02E927770AQ Hardware version: H54 Serial number: TFK01802081139� ODX name: EV_TCMDQ250021 ODX version: 001001 Long coding: 0014 Trouble codes: P170100 - Transmission control unit locked static Date: 2019-01-09 19:38:27 Mileage: 83350 km Priority: 0 Malfunction frequency counter: 1 Unlearning counter: 255 |
