Carista
#21
Also for the convertible:
The control button needs normally to be raised to lower the top and lowered to raise the top. While something we can get used to, it is certainly not something that is intuitive. It is the opposite of every other convertible I have owned. The way the windows are is a pain also. They should move down when the top is lowered and up with the top is raised. Also control button needs to be held in position for full motion of raising or lowering and is not a one touch. All are desirable as yes no options.
#23
Hi,
I've got Carista v3.3 on iPhone, and your hardware adapter, and I get many fewer of these customization options on my 2017 S3 than what you have listed here. For example, I have no option to select the sunroof action on long press of lock or unlock. Nor any daytime running light options. Nor any item regarding Lane-Change flasher count. And other missing items. Any ideas?
Thanks!
No, it's an additional display that comes up in the vehicle data that shows you how much fuel you put in last time you refueled.
#24
#25
Sounds good, thanks. We'll take a look when you submit the report.
#26
#28
I've sent a debug report, as well as an email to support with screen shots of my app. Aside from the issues I'm having regarding many coding options simply being absent from my menus, I have another issue. Now, regardless of settings, the nice beep that used to be there when I locked the doors w/ the key fob or the door handle button is now gone. Bummer.
#30
