:: ECS Tuning :: Keep Your Cool | NEW!! Audi 8V A3/S3 Turbo Blanket
Audiworld Basic Sponsor
As most of you know, turbos expel an immense amount of radiant heat. This heat only adds to the already sweltering under-hood engine temps derived from normal engine operation. Containing said turbo heat through insulation is key in the pursuit of lower intake temps, increased efficiency, and improved component life.
Made in the USA by a world leader in turbo insulation technologies, ECS Tuning is proud to introduce the ECS Turbo Blanket for your OEM turbos. Simply follow our installation PDF and get on your way to lower under-hood temps and increased overall engine efficiency.
Key Features
- Expect lower intake air temps than before as the associated induction parts are no longer being heat soaked to such a high degree by the hot turbocharger.
- Turbocharger response time is also improved (less turbo lag) as the heat energy is contained within the turbine housing. By containing all the heat energy within the turbine housing, this creates more pressure, more pressure is more energy, more energy available to spin the turbocharger faster in the lower RPM range!
- Made right here in the U.S.A. by a world leader in turbo blanket technologies and manufacturing. The exterior layer is crafted from heat treated fiberglass, then bonded with molten aluminum and then molded into a tight weave per our specifications for added resiliency. The inner layer is made from a high temperature resistant Silica that is good for temps up to 1,350° F! Stainless steel mounting anchors along with the included stainless steel wire tie secure the assembly in to position for long lasting, durable operation. Constructed in to two pieces to aid in installation.
Keep Your Cool
Click HERE to order or for more information
Fits:
Audi 8V A3/S3 1.8T/2.0T 2015+
Be sure to check out our -----> Installation PDF
