Fuse Panel next to steering column
How do you pry open the fuse box panel next to steering column and next to headlight controls for 2017 a3. I've tried pulling it by hand. It the marked areas are super hard to pull and manual doesn't state how open. Need to change a fuse out for interior lighting because I was swapping interior lights for led and when I got to glovebox it sparked and now no interior lights are work including trunk. Bought bulbs from ecs tuning and would have been nice if they wrote in their instructions to unplug the wire for glovebox bulb since current is always running once you open glovebox. Instead it just says to pry it open and swap bulb out. I didn't put bulb in perfectly bc it's so tight in that glove box and can't see and as LED wiggles into spot it sparked everything. Apparently, f29 7.5 amp brown fuse needs to be replaced. Can anyone help or let me know if I'm choosing the right fuse to replace? It is only a fuse that needs to be replaced, right? Appreciate any help!
Bump
Originally Posted by score0412
(Post 24888784)
Bump
Yes, bought ziza ones. Looked in owner's manual and no real instruction. It just has two arrows pointing how and which corner of panel comes off but doesn't say how. Literally, used a lot of hand force and nothing. I feel like if I tug it to the max I'm definitely going to break tab or panel or something.
I have the same problem. I don't want to pull too hard and break it. Especially since there is an "airbag" sign on the cover.
Did you manage to open it? I don't want to pay my dealer $90/hour just to replace a fuse. |
Originally Posted by jeanpierredemontigny
(Post 24915865)
Thanks. Will try this. I actually went to the dealership today. The tech rep (after checking with mechanics) showed me how to open the side panel. I did that when I got home but this is wrong. This is where fuses were in older models.
Quick update. I tried again pulling hard and not worrying about the air bag and it worked. Thanks for the instructions.
fantastic! Glad you got it done and yes, tech thought it was on side also but it's not the case.
Fuse changed. I should have come here first rather than drive all the way to the dealer. The internet come through again!
