going from 18" to 19" causing vibration on high speed?
#11
My friend used his spare wheel spacers to push wheels out so they look better. I think that is most likely the culprit of my problem. He said to get wheel balance and that should fix it. Can someone verify that? Or should I buy new spacers ? What would you recommend? Please include link. Thanks
Lastly are the wheel spacers seated properly on your car and are they in good condition and not bent slightly from say improper torquing pressure/order.
The odds are that the wheels and tires themselves are balanced perfectly from Tire Rack so unless some damage occurred in shipping or the off chance you threw a weight already, the overwhelming likelihood is that your vibration issue is being caused by the hub/spacer situation. There are plenty of spacers out there of dubious quality.
There are ways to measure the runout to pin down exactly where the problem is coming from but that's tedious and involves tools that i'm pretty certain you don't have laying around. So you're left with a more trial and error approach.
Step 1. Find out what the center bore is on the wheels you ordered. If it's the same as the hub size on your car then you won't need hub centric rings if mounting the wheel directly to your hub (no spacers). If it's different then you will need rings.
Step 2. Start looking into potential issues with the Spacers.
#12
My friend said I should try the hub centric spacers. He is a car guy and does lots of DIY with his Audi's. I recall tirerack package came with rings and I doubt they are hub centric . I don't know if I am better off replacing spacers with hub centric ones or just get the centric rings. If I leave them as is and it causes vibration during high speed, will it eventually do any damage to the car? Sorry for dumb question I am a newbie when it comes to this.
#13
#14
#15
I have ECS spacers (S3) and never had any vibration issues. I have used MTM on previous Audis with no issues - but if you use cheap spacers or ones not specifically designed for your Audi you will have the issues you describe
HarnessedLunacy
Wheels & Tires Discussion
12-22-2003 10:35 AM
The Jester
05-26-2003 03:33 PM
