Has anyone done a Valentine 1 hardwire on their car yet?
#21
attached are a couple of pictures to show what I did and where I tapped into the fusebox...
where the fuse box is
the share-a-fuse I used and where it was
Blendmount with Passport Max - wire snaked up on side of mirror, headliner, and then down the A-pillar into the fuse box
Where did you attach the ground?
#22
you have to take off the panel that you only see when you have the door open on the side of the dash. once that's off you will see metal, pained black, that you can sand down and onto which you can attach the ground. I didn't take pictures of this unfortunately.
#24
#25
Any advice on how to get this off on the 8V A3/S3? I'd be open to trying mirror taps for the first time but don't want to bust my mirror in the process. I honestly wasn't even sure whether we have the right power ports in the A3/S3, given lack of homelink.
#26
For anyone that has done mirrortaps - how did you get access to the power. Did you have to pop open the plastic housing where the mirror attaches to the windshield?
Blendmount.com - MirrorTap Power Cords
#27
I just wired my 9500 with this and it was one of the easiest things I've ever done on a car.
Amazon.com : Radar Detector MirrorWire Power Cable - Escort 9500iX, 8500X50, SoloS3, Redline : Car Electronics
#28
MirrorTap FTW.
clean
no trace of anything, when you remove it.
you're not fussing with airbags.
#29
Yeah I already had my wire otherwise I would have mirrored tapped. Important to mention though, the install is also clean, no trace of anything when removed, and didn't require fussing with airbags.
#30
I don't have my S3 yet but on all my other vehicles, the connector that plugs into the mirror was exposed and I just wedged the ends of the Mirror Tap in there.
