New RS3 owner here! Question about these massive front brakes and rotors
Hi everyone, wanted to say hello first! I just traded in a 2016 S3 that I owned for 3 years and upgraded to an RS3. I do have a question incoming, but first, a few pictures
(Google drive links)
https://drive.google.com/open?id=1Iy...L3f5cbux5wNGyW
https://drive.google.com/open?id=1zH...CBrbDJAa7KvdLD
https://drive.google.com/open?id=1IY...xynSIv4wZMLOWi
NOW! Onto my question!
I've never owned a car with drilled, vented, slotted (or otherwise) rotors, so, coming off of owing an S3 with solid rotors, something I've noticed is that the rotors on the RS3 are loud! They seems to make a constant "click" type noise when not applying brakes (much like a bicycle with something stuck in the spokes), and make a fun "rain stick" sound when applying the brakes. This is only audible when the windows are down and I'm driving near a concrete barrier or a high curb. I'm assuming this is fairly normal for vented / drilled (or otherwise) rotors. If any other RS3 owners could confirm this, that would be great.
Thanks everyone!
Thanks everyone!
I have drilled rotors on my M3. They make no noise that I can hear. I will say that aftermarket pads like Akebono are a good investment. So much less dust! Sweet car.
Thanks everyone!
Thanks everyone!
If it doesn't go away after some time, take the car back to the dealership and have them make sure everything is ok.
Have had drilled, slotted, dimpled ect rotors. On most of my cars when the rotors where drilled or dimpled I got that clicking noise. If you are driving and next to a barrier on the driver side while driving. press the brake slightly to slow down you should hear the noise get louder. This does it on my RS3. Just sharing my experience not saying its correct but have been told its nothing to be concerned with.
I can't say I've experienced a clicking noise on high performance brakes ever. I daily an RS5 and regularly drive cars such as the TT RS and R8. I'm gonna be driving the RS3 in a few weeks, so I'll try to pay attention to this. However, high performance brakes are noisier than your average brakes. Slotted rotors more so, then just drilled. Different brake pad compounds also make different noise. I went from the stock drilled rotors on my RS5 to drilled and slotted aftermarket rotors and also different pads. The brakes are noiser now, but not unpleasant. They make sort of a swooshy, low frequency humming noise when coming to a stop and it's basically from the slots passing under the rotors and air/gases escaping. The primary point of drilled/slotted rotors is so that air, debris and gases from the pads can escape. That will make a certain amount of noise. Very important and I keep emphasizing this is to properly burnish your brakes, or otherwise you'll risk uneven brake pad material deposits and subpar performance. If you have the CCBs, then there is additional considerations. The CCBs need to be warm to perform well, so the brake system automatically applies slight pressure to produce friction even when not braking to heat up the pads. That can cause extra noise. Also, the CCBs and standard brakes have the disc wiping feature, so while driving in the rain, the brakes periodically apply pressure to the rotors to wipe the water film off them. So, that could also cause some extra noise. You didn't specify if the noise is weather dependent.
I have the big Brimbo's on my mercedes and they are "loud", but like a swoosh.. They also burn through pads quickly if your are on it all the time. You can get longer lasting pads, but they end up making a god awful squeel if you do.
Thanks.
I have a new (1500 miles) RS5 Coupe. In the past 100 miles, I've noticed a significant "grinding" noise when slowing, in city traffic. Not slowing from high speeds, but from say 40 mph to zero at a stoplight. This happens on dry roads, with the car clean and dry, and no water or moisture on the wheels/axle/brakes that I can discern. Is this also a case where the pads need to "set"? If not, am wondering about contacting dealer for a service appt.
Thank you!!!
