One spare to rule them all (building an RS3 spare tire)
Hi All
Since I'll likely have to mail order a replacement tire if/when I need to replace one, and the US-spec RS3 doesn't come with a spare tire, I'm thinking of building my own spare to save some downtime and possibly a tow.
I've got the staggered setup so am wondering if I can get away with a single tire (presumably the 235/35R19) and wheel to serve in any location or if I need to get one of each size? I'd like to get an OEM clone, just to keep
the look consistent, but will likely just go with whatever looks reasonable and cheap on tirerack, since the idea is just to have spare while I'm waiting to get replacement tires in and mounted, although that could be a week or more....
What do you think would be the way to go?
Thanks,
scot
I'm considering this at tire rack - with a stock tire: https://www.tirerack.com/wheels/Whee...01AMF&i2_Qty=1
Thanks,
scot
maybe just buy the same space saver that comes in the s3? some guys selling theirs online for like 100$
-saves space
-less of a hassle to install
-less weight
-less cost
Who cares what it looks like? It will be on for a day at the most. And its a double ended problem. Look like a weirdo with a strange discolored wheel that differs in size and shape that the others. Or the lame tiny black space saver- but really how lame is it? everyone gets flats.. they will understand.. don't be so concerned about that- in this type of situation especially..
maybe you can even get all the parts from the s3 to keep in stored away under the mat. It is good piece of mind to have it back there for sure...
By the way how were you planning on storing the wheel you get from tirerack? If at your house then its a fail because you wont have the wheel when you need it. And if you bring that beast into the car it will take up the entire trunk and slam into everything..
-saves space
-less weight
-less cost
2019 RS3 ordered 1-5-2019
-saves space
-less weight
-less cost
-saves space
-less weight
-less cost
Terry
this is just a hunch but i am guessing that space saver from the S3 won't fit over the RS3's brakes. there is a whole thread on another audi forum that has aftermarket wheels which will actually fit the RS3. it is not a very long list and from reading, the issue seems to be brake clearance.
That makes perfect sense since the RS3 has those huge 8-piston brake calibers up front.
Terry
i believe the only way it would work is on the rears. so if you got a rear flat, you'd be okay. if you got a front flat, you'd have to move one of the backs to the front, then use the dummy in the back. if you're stuck on the side of the road, i don't quite know how you'd manage that with one jack.
Yeah, I think the issue is the brakes, and living in Hawaii, I would likely need to run a spare wheel for a week or more as I await shipment of a replacement. That's why I was thinking of a "real" spare.
Do you think I need one of each fitting, or could I run the smaller spec tire on the front for a while if I had to?
Thanks,
scot
Thanks,
scot
Thanks,
scot
Thanks,
scot
In any case, carrying one spare seems tough enough to fit in the trunk, I think two would not be possible.
Thanks,
scot
Thanks,
scot
i don't know about running a single tire in an odd size with the staggered setup but i would think at worst you might get some TPMS warnings and or occasional TC warnings but nothing you couldn't live with for a couple weeks.
