Passengar Airbag warning light is on
Recently purchased a 2016 S3! Just noticed the "Passenger Airbag is off" warning light is stuck on. How do I turn this thing off? Anyone else have the same issue?
What happens when someone is sitting in the front seat? |
Originally Posted by heisnuts
(Post 25235245)
If the light is on when a passenger is seated, there's a problem. If it's annoying while driving alone, a 3 inch strip of electric tape worked for me.
It did go away with a passenger. Not sure why this light is necessary. Might do the same and put on electric tape
Did you scan it for Hard/Soft Codes??? (Minor bumps can set off Codes)
Originally Posted by purwin56
(Post 25235192)
It should go out as soon as you start the car unless there’s an actual error code. Did they scan it and find any codes? Shoot back a response...and remember, "Indicator Lights are there for a reason...you may not like them, but they serve a purpose to warn and caution." :cool: |
It stays on unless a passenger is in the seat and does not go off after the car is started.
(Post 25235192)
