RS3 2018 - winter tires size
Hi.
I drive RS2018, with 255/30/19 front and 235/35/19 rear summer tires.
I'm not sure about, what kind of winter tires are forced to be use?
Just replace summer tires to winter witres with the same sizes, or use the 235/35/19 at all 4 winter tires as in the manual? (but what about the front rims, can we use the same or have to bought narrowed?).
Thank You.
Thank You.
I bought dedicated winter rims as I feel that's 'better' for the tires and easier to swap (I can do it myself if I want, even). I went 235/35/18 as there's a lot more tire options in 18" than 19" and went with the Neuspeed wheels.
Don't you think that with the same size tires and smaller rims will cause that the speed indicator will show you wrong results?
The size of the wheel must be exactly the same when changing tires or rims or both.
Best regards.
Best regards.
taller sidewalls does limit the difference, and a great question: I've no idea how much 'input' the car takes from GPS when calculating speed.
Audiworld Senior Member
https://www.wheel-size.com/calc/?whe...cl=25mm&sr=0mm
rbirk
37
02-20-2013 11:24 AM
NvFlw
Pacific Northwest Discussion
10-16-2004 09:52 PM
