RS3 break in procedure
#21
You can take this as you wish but first off, the manual with the car is A3 specific, not RS3 so I would not take the instructions as gospel. Further, at the A0A open house a few weeks ago, I had the opportunity to speak to the project manager for all RS cars. I asked him specifically about break in and he stated that no break in was necessary on an RS3. I tend to believe that he may be a reputable source of information. That being said, break it in as you see fit - if you're more comfortable driving easily, go for it. If you want to drive it like you stole it, go for that. It's your car. I don't think driving hard will break it but you have to drive to your own comfort level. I would take oil changes to the same level - do what you think is right. The project manager was perfectly comfortable with the recommended interval but I chose to change my oil at 2K mies - just personal preference. The oil was clean and the change probably unnecessary but I did it anyway. Ultimately, a lot of the advice being given is old school advice but the bottom line is following that advice does no harm. So, drive conservatively if you wish and change the oil as much as you want, it's your car.
#22
1 Post
Re: oil changes: I was pleasantly surprised to get an email from the dealership offering me a free 5,000 oil change and then continuing on the regularly scheduled maintenance starting at 10,000. I will definitely take them up on their offer!
#23
- A project manager is generally not a technical resource to a project but someone who manages a set of requirements, budgets, timeline, resources, and risks. I'm an IT PM and when I tell you the technical aspects of a software implementation are going to be "just fine"... well that's not based on much more than whatever some developer told me to keep me off of his back.
- Audi has a vested interest in telling you what they think will make you happy. The cars need to be reliable up to a point, but they also make a fair amount of money on back-end service. If you investigate VW/Audi oil consumption you'll see a few people who followed the recommended services and have high oil consumption and then the manufacturer says this is normal.
Again YMMV, I'm certainly on the overly cautious end of the "spectrum".
#24
2019 RS3 ordered 1-5-2019
Is MORE POWER the most critical criteria for your engine or is LONGEVITY? I'm planning on having my RS3 longer than a couple of years so I'm happy to sacrifice a few HP for increased reliability and lifespan.
The interwebs are full of all kinds of conflicting opinions. All you can do is read as much info as possible and weigh the information based on what makes sense to you. There will always be something that will confirm what you'd like to believe, "You can drive it like you stole it from day one." or "You must drive it like the Amish made it from wood." All you're going to get is opinion, you need to decide the credibility of the source.
IMO engines are certainly built with much tighter tolerances that make break-in LESS CRITICAL than once was the case but metal parts will initially need wear together and this wear created metal bits which are not desirable. The way to remove the bits is with an oil filter and to remove the oil in which the bits are suspended. I chose some really short change intervals in the beginning because I think it's cheap insurance.
Additionally, something that isn't generally discussed, is the wear on the Turbo bearings and seals from the increased metal bits due to engine break-in. I think these components are more sensitive to wear than your engine cylinder and rings.
Here are a few sources that I think are somewhat credible YMMV...
2016 Article from Road and Track
Engineering Explained video on how to treat a new car
#25
At the risk of being told that I'm "old-school" again, you shouldn't change your oil too soon either, I believe that there are special additives in the factory oil that aid in break-in and that you should use that oil for the recommended interval.
But to back-up my old school notions, I trust these guys quite a bit;
New Car Care ? How to Take Care of a New Car
Best Engine Break-In Techniques - How to Break In a Brand New Car
and maybe the question should be, why NOT break-in a new $50 -$70k car gently?
#26
I hear what you are saying, (seriously not trying to bust your ***** here, please read my entire post) but what you just said is part of the problem. The two main schools of thought for break-in procedures both have decades worth of hearsay and second/third/forth hand information on the subject, with little to no actual documented test data comparing the two. Someone is going to come into this thread and see what you just posted, and in their head take that as gospel and then start relaying that info as "an Audi tech on a forum told me that they do NOT use conditioners in their oil from the factory.", or something of that nature. All that being said, if I was building a race engine with little concern for longevity of the engine and only interested in max power, I would likely prescribe to the "drive it like I stole it" mindset. This being my daily driver that I plan on keeping over 100k miles, I'll say that until the team of engine design/testing engineers and technicians comes to my door with a hard drive full of all the historic engine data and test results that shows wear on bearings, piston rings, cylinder walls, etc. under various break-in methodologies, then I will be continuing to follow the method that the owners manual recommends, and put my trust in the engineers good judgement (Audi lawyer/accountant input not withstanding).
#28
Just to play devils advocate here a little...
No disagreement with you at all. Although I do think the manager for all RS cars may have a bit of credibility and, hopefully, has ongoing dialog with the engineers, I agree with you and see no harm in breaking a car in gently, within reason. I was on another forum where a poster was horrified because he hit the limiter once while in his 1000 mile break in period. I'm not saying that you should ne hitting lunch the moment you leave the dealership but I don't think driving a bit more aggressively than the A3 manual recommends will make much difference in the long run. As to oil, I agree that changing it more often than recommended can't hurt either. It may not be necessary but it does no damage.
#29
Yep - and you left out the turbo, most people do, lots a moving parts there too
