Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
RS3 oil change- need a filter wrench or not?
Old 12-16-2018, 12:59 AM
zzcett's Avatar
Default RS3 oil change- need a filter wrench or not?
HI All
I'm getting ready for my first DIY oil change on my '18 RS3. I see various references online to a filter wrench tool, but videos that show there is no tool that works other than filter pliers. Is there a good tool to make the filter housing removal easy?
Thanks!
Old 12-16-2018, 04:27 PM
morris39's Avatar
Originally Posted by zzcett
HI All
Thanks!
As no owner of a an RS3 wants to reply ( over 100 views) I will chime in with a general comment. If the filter nut is plastic as it is for 2.0 TFSI motor, then a properly sized socket (32mm for 2.0) is the correct tool. A wrench may leave evidence of your skill otherwise.
It's disappointing that people do not offer help on this forum. In my view owners' experience is the most useful feature of forums. As a first time Audi owner I have had a generally poor response to simple questions.
Old 12-16-2018, 10:27 PM
sbehba's Avatar
I used this
ABN Oil Filter Socket Wrench, 74.2mm ABN Oil Filter Socket Wrench, 74.2mm
. Would recommend, it's hard to get a good grip on the filter housing. Also the canister drain tool part #T40057. Not necessary, but makes removing the filter a lot cleaner.
Old 12-16-2018, 11:34 PM
zzcett's Avatar
Thanks. Ordered!
Old 01-19-2019, 04:17 PM
zzcett's Avatar
Following up - used that wrench today and it worked perfectly.
Also a note that the crush washer on the oil drain plug does a very good job of appearing to be part of the oil pan. Don't be fooled. It came off easily once I put a flat bade to it.
Hpk
Q7 MK 1 Discussion
07-21-2017 06:53 PM
Tomasz@Startup
A4 (B7 Platform) Discussion
12-04-2006 01:20 AM
stilljester
10
11-01-2005 01:08 PM
JoeO
11
08-04-2005 08:27 PM
TRM
05-06-2002 01:05 PM
Quick Reply: RS3 oil change- need a filter wrench or not?
