RS3 Sedan Key FOB Upgrade?
#51
Yes even the start stop button.
This is an old video of mine -
There is a version for you S3 lot as well, has an 'S' logo at the back but the key is not high gloss black like the RS key, it is matte black.
#52
Canada is go!
Thank you Matthew for sending me this video.
https://www.youtube.com/watch?v=9EC2vY2QK7w
#53
thanks aoon. really love your car and how you're helping to push the 8v game forward
#54
#55
I can't dish out part numbers as there is an extremely complex procedure in order to calculate which key you actually need. Information comes from your VIN number and current key for starters.
#56
Good news to all. Key coding on my RS3 was successful. I now have a working TTRS key fob on my RS3 .
The issue you will have is that no Audi dealership can supply TTRS/RS7 etc keys as they must be ordered via VIN and the system won't even let them place the order.
I now have a supplier for these keys fortunately, so can supply any VAG smart key you fancy.
The keyfob itself comes partially coded to VIN, the key blade comes cut to VIN.
Keyblade on the TTRS is not wide enough and will NOT work on the RS3. However it is possible to swap your original RS3 key blade over to your TTRS/RS7 fob.
I can supply the TTRS style key for £300. The key will its pairing process completed via a dealership, or any workshop with an ODIS interface. This can also be performed remotely by myself however you must purchase an VAS5054A interface (£60)
Hope this helps.
Hope this helps.
#58
i see. so reading your posts, let me see if i can get this down.
we need to buy a special version of the key, most likely from you as it would just be easier.
the key is only able to be programmed once to a car.
you need to have our specific vin to order this key.
once we get the key it can be programmed by our dealership.
or.
you can program it for an extra fee. (what info do you need from us to do this?)
would the dealership know that it would be programmable as this is not meant for other cars and may just turn us away?
or.
#59
or.
or.
Correct!
Yes,
Yes,
Yes,
It can be done by myself remotely but I would leave that as a last resort as it requires you to purchase a dongle and then install 18gb's of dealer software. I have not had a single dealership worldwide knock it back so far and I have posted these keys to several locations around the world. Over 30 different dealerships without issue.
The stance dealers have on this so far from what I've seen is that they will be sceptical and tell you they don't think it will work, however they will be more than happy to charge you 30 minutes labour for trying. The key comes packed in genuine VAG Group packaging with your chassis number on the label. They would have a difficult time knocking the request back. I've not had a single key not work so far around the world, as these keys are ordered and coded to VIN they just work.
Thanks
#60
Correct!
Yes,
Yes,
Yes,
Thanks
Yes,
Yes,
Yes,
Thanks
