Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
RS3 TPMS Individual Tire Pressure Display
Old 11-13-2017, 01:23 PM
Chi_Nardo_RS3's Avatar
Default RS3 TPMS Individual Tire Pressure Display
Hey Guys,
Does anybody know if the RS3 displays individual tire pressure? I noticed that my wife's AMG CLA45 does and so does the BMW M2's. When I searched I couldn't find anything showing individual tire pressure.
Old 11-13-2017, 01:29 PM
superswiss's Avatar
Received 1,065 Likes on 740 Posts
Yes, if you get the Dynamic plus package. Part of that package is direct TPMS which will give you pressure and temperature for each tire. Standard TPMS is indirect, which doesn't use sensors in the tires and instead determines loss of pressure by measuring oscillations in the wheel assembly via the ABS senors. The indirect system is relative. It learns the reference pressure and then reports if it sees a 20% deviation from the learned reference, but it doesn't know the absolute tire pressure.
Old 11-14-2017, 03:10 AM
BaltimoreCaesar's Avatar
To add that ability, is it just a matter of swapping out the TPMS valve stems, and code in teh display via OBDeleven
Old 11-14-2017, 08:30 AM
superswiss's Avatar
I doubt that Audi will install the receiver hardware in the car, unless you opt for direct TPMS.
Old 11-14-2017, 06:26 PM
dus10r's Avatar
I love the tire temperature data, more so than the pressure.
Old 11-16-2017, 08:49 AM
big residual's Avatar
Seems logical. But even if it's not just swapping valve stems, I wonder how hard it would be to retrofit a non-Plus RS3 to have TPMS. Would be great for track use.
Old 11-18-2017, 06:26 AM
michael818's Avatar
I think there is a bit more to it than that:
Direct TPMS or direct tire pressure monitoring systems refers to the use of a pressure sensor directly mounted on the wheels or tires of a vehicle. The pressure inside the tire is measured using a pressure transducer with the pressure information being subsequently sent to the vehicle to warn the driver of under or over inflation of a tire.
The pressure information is commonly transmitted to the vehicle using radio frequency (RF) technology, through systems using mechanical, electrical or magnetic methods. A typical direct TPMS (e.g. Ford, BMW or Toyota) comprises the following components on a vehicle:
  • A direct tire pressure monitoring (TPM) sensor fitted to the back of the valve stem on each wheel.
  • A TPM Warning Light.
  • Unique identifier (ID's) for which tire is providing the data including speed and the direction of rotation.
  • A tire pressure monitor engine control unit (ECU).
  • Antenna(s).
  • Controller for periodic measurements.
  • Source of power.
  • Diagnostics and wake up system.
diffuser
Q7 MKII Discussion
33
11-20-2017 11:34 AM
profi
Q7 MK 1 Discussion
09-03-2007 02:38 PM
barrem23
12
11-21-2002 10:59 AM
SKI
Wheels & Tires Discussion
04-09-2001 05:31 AM
Quick Reply: RS3 TPMS Individual Tire Pressure Display
