S3 or RS3 as Daily Driver
#31
Haha! No canyons like that here in Minnesota-just a whole lot of lakes and woods. Can honestly say I'd probably have plenty of fun with on-ramps around the Twin Cities with my commutes.
Quick question- how's RS3 exhaust note change in comfort mode? Asking for the better half..if she drives it I doubt she'd want the 5-cyl symphony in its full glory.
#32
Audiforme but aren't you comparing manual supercharged engine v. turbo charged engine in the S3/RS3? If so, that will of course be completely different. I too had an S4 recently and that engine was phenomenal and zero lag, naturally. In terms of the S3 (as I cannot speak on the RS3) I'm guessing you had the car in automatic mode, and probably not sport mode? If it's in sport mode it's basically hyper and even a bit over the top in some ways as far as its shift points, etc. I like driving it manually knowing exactly when it will shift so I don't experience much turbo lag at all actually.
#33
Hmm strange. I haven't had that experience with my S3 so not sure what that's about. It almost seems like the transmission was in 2nd or maybe even 3rd gear when you tried to punch it from a dead stop. If that's the case, you will definitely experience disconnect with the throttle.
As for the RS3 there seems to be some suggesting there's a bit of turbo lag. I think that will be the case for pretty much any turbo powered engines, some just worse than others.
#35
EDIT: And I forgot, putting the Quattro system in Dynamic mode may also help as that is supposed to engage the rear wheels sooner and more proactively.
#36
Sounds like ESC may be retarding the engine to avoid wheel spin. Partially a consequence of the FWD-biased Haldex system. It takes a moment for the rear wheels to get power and if you are turning, then the Haldex clutch can't fully close and lock the drivetrain so you are very FWD-biased in a situation like that. You can try putting ESC in Sport mode. The RS models generally have higher ESC thresholds, so this might be less of an issue in the RS3, however the RS3's Achilles heel is still the Haldex system.
#38
interesting. This is exactly what I was doing, exiting the dealer parking lot onto a busy street. There was a huge delay and car was not accelerating and traffic coming to me fast. Very scary! Once it took off, it went, but it was dicey for a moment. None of my previous Turbo / Torsen / Manual cars have done this. Has to be something with the haldex and transmission programming I guess.
#39
It's very different in feeling from normal stock EA888 throttle response lag or actual turbo lag. I save my really janky moves for turning left.
#40
im dsg, and when in manual mode, when i downshift from 5th to 2nd too quickly, it take a second or two for the transmission to acknowledge 2nd gear. there is a slight hesitation before 2nd engages and i have power. seems the dsg can only accommodate downshifting 2 gears, not 3.
