Switching to Manual Shift from "D" vs from "S"
#11
Haven't checked this yet myself but if "D" = "Comfort" and "S" = Dynamic, does that Engine/Trans. checkmark in the Individual Drive Select settings change when you toggle with the gearshifter?
D/S selection with the gearshifter obviously has priority over all the Drive Select modes.
#12
Yes, there is. In Dynamic Trans D, the steering, suspension etc., except engine/transmission are in Dynamic and in Comfort Trans D, the steering, suspension etc, including engine/transmission. are in Comfort.
#13
Just to add clarification, in manual shift mode in my '17 S3 it does indicate what gear I'm in (M1 thru M6). It just doesn't show the additional "S" like the R8 does. In regular D mode I don't see what gear it's in.
#14
Here is what the manual says. I would think if D always meant Comfort/Auto, and S always meant Dynamic, then it would be spelled out here and it isn't.
They did however point out that Engine sound settings change between subtle/sporty when changing from D to S.
#15
I saw that they changed this table for the A3 and some other recent models, and I'm not yet sure what to make of it. In the real world, I have yet to feel a discernible difference between engine/transmission in Comfort D vs Auto D. Here is what the table used to look like for other Audi models. This particular one is from my RS5, but it's the same on other models. Both Comfort and Auto show Balanced for their characteristics. So, I'm not sure if they changed it because it was confusing to show the same characteristics for the two modes or if they indeed added an additional throttle map and shift program. I don't actually use Comfort mode very often and if I do, it's for cruising on the highway, so I have to go out and experiment with this again to see if there is a noticeable difference on newer models.
#16
I've yet to set anything to AUTO mode on my S3. I use individual and set everything to dynamic except the engine/transmission. Then it's just a matter of moving the gear select lever from D to S to be full dynamic. In addition to my APR ECU Stage 2 work, I also included the TCU upgrade. I now get to see what gear I'm in regardless of transmission mode. Very handy. Lately, I only use the manual mode and paddle shifters. Found some nice paddle shifter extensions which allow me to grab the paddles from pretty much any position my hands are on the wheel. With the TCU update, the standard D mode but in manual, works quite well. S mode and manual definitely kicks things up a notch however. Great for nice, open twisty roads. Have the winter wheels/tires on the car now and have to be more mindful however.
#17
#18
#19
Here's my question, I have all the individual settings set to Dynamic except Suspension and Engine/Trans. I have those set to Auto. I always put the car in S mode. What happens to those two settings that I have in Auto? Are they switched to dynamic when I put in S mode? So essentially I'm in individual mode, but when i put it in S, I'm really in dynamic? When I shift to S, the revs come up a bit and it definitely sounds a touch louder.
#20
1 Post
