TYRE REPAIR KIT question
I had a very bad luck and after replacing two front tires I have drove on top of a hole on the road and the right tire lost all its air pressure immediately.
Tomorrow I'll go to the tire workshop again but before that I need to use the TYRE REPAIR KIT to put some air in. According to the manual, I need to connect the compressor to the sealant can and the sealant can to the tire. Can I try first to connect the compressor directly to the tire? I'm not sure that there's really cut or puncture. Thanks |
Try with just air. Once you put in the sealant, I believe the tire cannot be repaired (the sealant ruins the inside) and you have to throw away the tire. Using the sealant is a temporary fix to get you to a service facility. If you use just air you may be able to have the tire repaired.
Originally Posted by steve111b
(Post 25241005)
Thanks both.
I have tried without the sealant for a minute or so and nothing happened. I assume the puncture is too big to repair. |
Update:
It was a very big puncture. No way to repair using the kit. On top of that, the back tire also got damaged from this pot hole. I've been towed from my home to the service facility. They replaced both tires. Damage: 850$ |
Don't you have a spare tire? I thought all Audis still come with a spare.
Originally Posted by numerobis
(Post 25241643)
(Post 25241643)
Originally Posted by Eran Levi
(Post 25241802)
In my country, all luxury cars (Cars above 80K USD) has no spare tire. Haven't tried to figure that out but I assume that they think that "reach" people will not use the spare tire but will call for assistance? Just an assumption....
I prefer to have a spare tire. Doesn't matter how "rich" I am or how cold it is (it doesn't go below 50F here)
