USB port not charging
My 2016 Audi A3 USB port recently stopped charging. I verified the cable is not a problem and the port worked on the same device previously. Does anyone know if there is a fuse assigned to this item that I can verify or anything else I can try? Seem like a small issue to bring back to the dealer for service, but the car is relatively still new.
Thanks!
Thanks!
Thanks!
Thanks!
This is the port in your glovebox correct? If im not mistaken the fuse is part of the whole mmi circuit. So if your radio is working chances are the fuse is not blown.
be aware that your car needs to be on for the usb port to charge. if you want the power to always be on you may need to use the 12v socket. look in the manual to move one of the fuses to 'always on'
it will keep the 12v port on even when the car is off. quite helpful when charging phones you leave in your car
I had the same problem
My phone quit charging twice this past weekend on a trip. All I had to do was wiggle the cable a few times and it started charging again. Loose connection either at the phone or in the armrest. I leave the usb cable plugged in all of the time, and that may have loosened the connection.
The 2016 may be different, but I thought in the 2015 A3 the USB was for power only. Wish it was also for data.
It can be set to any of the options via VCD, but Audi decided to dumb it down depending on your car's model/location. Thought it was pretty interesting find while in the VCD settings. I only have the 3.5mm jack so haven't been able to play around with it - though I have the module , just not the cables to connect it to my MMI. I'd suspect it will act just like the SD card slots if data is enabled.
Maintenance
Thanks for the response. The port is in the arm rest console, but I assume that was you meant. I'll have to look for the ability to turn the 12v port on at all times, that would be helpful. Without an easy fix on the USB, I'll wait till I'm bringing the car in for other maintenance.
