Audi A3 / S3 / RS 3 MKII Discussion forum for the 2015 to 2022 Audi A3, S3 and RS3 - including the upcoming E-tron and TDI models
USB port not charging
Old 09-05-2016, 01:56 PM
  #11
metelc's Avatar
Originally Posted by uldisv
I can confirm F16 fuse is down. Installed new one - but it is down again. Will go to dealer service.
Since I checked my fuses and I don't have an actual fuse in location F16, I'm going to assume that isn't my problem. Must not be needed unless you have full MMI capability.
Old 09-07-2016, 01:43 PM
  #12
njajr's Avatar
Default VCD settings for USB Port?
Originally Posted by mroberte
It can be set to any of the options via VCD, but Audi decided to dumb it down depending on your car's model/location. Thought it was pretty interesting find while in the VCD settings. I only have the 3.5mm jack so haven't been able to play around with it - though I have the module , just not the cables to connect it to my MMI. I'd suspect it will act just like the SD card slots if data is enabled.
Can you say more about what settings are available? Can this be done with VAG-COM?
Old 09-10-2016, 12:24 AM
  #13
mroberte's Avatar
I'll try and figure out the info tomorrow for you.
Old 10-26-2018, 04:42 AM
  #14
wrighty444's Avatar
Hi
A4 2012 Cigerette lighter and all USB ports stopped working. Went into Audi for a recall job and I asked to check them out. No voltage at ports but voltage at fuses.
They wanted £200 to investigate further. Report states J519 wiring and J807 relay static report. Not found much from online search.
Anyone any ideas where the J807 relay is?
Old 03-20-2019, 10:00 AM
  #15
Anhators's Avatar
Did you find the solution??
Lukas111
Audi A3 / S3 / RS 3
11-17-2016 11:03 PM
Bob1982
06-25-2013 06:01 AM
rooster 2
02-17-2006 05:09 AM
audiman231
06-29-2003 07:03 PM
Dr. Bombay
01-16-2002 05:13 AM
Quick Reply: USB port not charging
