Where to buy German or Euro outside mirrors?
Hoping to find a U.S. vendor, and anti-dazzle driver side for my S3. Drove a TDI A4 in Ireland for the last three years, and I miss the expanded view those mirrors provided. Thanks for any suggestions
Originally Posted by jberb55
(Post 24643105)
VWVortex.com - Side view mirrors It contains the part numbers. Try google search. |
The link to the parts numbers that the previous poster put up is accurate, I can attest, because I'm the one who wrote that post on VW Vortex.
As of August, I couldn't find a US-based company that had them. I was in London that month and bought the convex driver's side mirror from the Audi dealer in North London off the Finchley Road. They had them in stock but would have had to order the aspherical version. It cost me the equivalent of US$73 (this is heated, but not the anti-dazzle version). I have put it on my A3 and as those who have convex mirrors know, the field of view is vastly improved. By the way, US Audi dealers can't order these parts. When I gave one the part number it didn't even show up in his database. |
Thanks for the information and experience you shared on VW Vortex and in your reply here. It seems ECS has mirrors for other models; maybe they'll eventually bring in some for us.
Bought them at oemvwshop.com. Didn't get around to installing them until this weekend. I couldn't fit my fingers behind the glass... A flathead covered with blue painters tape worked great as a pry tool. Also pulled out all the rear headrests. Visibility much improved. Some small carbon fiber caps to cover the left-behind headrest hardware would be neat
(Post 24687650)
Were you successful pulling out the two outboard headrests? Like those there is the adjustment button on one "support"... On the other support, there is a small slot to release the headrest. You get at it from the center of the headrest. You have to use a small flathead to do it. If you already know that stuff and still not working, maybe apply constant (but not hard) upward pressure on the headrest while pushing on the screwdriver, then release the screwdriver, and push the adjustment button on the other side. Should pop out. Helpful to angle the seatback forward so the roof doesn't get in your way. Hope this helps.
Does anyone have a part number for the middle headrest? I want to swap the outside pair with the middle version. (assuming the posts are all the same dimensions) And I can confirm that the small screwdriver on the post without the tab works for removal.
Also, I think europrice carries the mirror inserts. Mirror Glass | Aspherical Blind Spot |
Try here... AUDI A3/S3/SPORTBACK/QU. [A3] (EUROPE) 2013 [8V-D-000 001 >>]: BODY: 88570. BACKREST, SPLIT Different p/n's for different covers
