Stock spring rates and sway bars for RS3 8P?
I've searched for some days for this info but seems there's nothing around the net. Do you know the OEM spring rate and the sway bars diameter for front and rear axles? I'm specially interested on the 2011-2012 model.
For now I've found these values for the spring rates but them seems to be excesively low and irreal for a car like this:
Front: 120 lb/in
Rear: 140 lb/in
And swaybars diameter info I've found:
Front: 20mm
Rear: 22mm
Front: 120 lb/in
Rear: 140 lb/in
Front: 20mm
Rear: 22mm
audidrvr
Audi Original "S" Cars
14
03-27-2008 01:46 PM
VAP
07-15-2007 06:42 AM
beemdubya
17
12-27-2005 07:39 AM
if i run 580F/660R spring rates on FK konigsports, should i also run a 19mm neuspeed rear bar or...?
s4indaworks
18
10-31-2003 05:16 AM
