EML on - Lamda Sensor problem
Hi,
I was wondering if anyone out there could point me in the right direction with a lamda sensor fault I'm getting on my Audi A3 2.0TDI 170 2007. It's causing the EML to light up constantly and after replacing the sensor, the light is still showing. In fact it came back on immediately. There were also a few voltage related faults which I've cleared and they haven't come back on as yet. I was wondering it all this was battery related or if the lambda sensor fault is an issue of it's own. The DPF was removed by a previous owner a couple of years ago. Don't know if this could have something to do with it.
Any help would be much appreciated.
Thanks
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
Component: R4 2.0l PPD1.2 G 1247
Revision: --H32--- Serial number: AUX7Z0FNFNG07A
Coding: 0000078
Shop #: WSC 66565 257 00032
VCID: 74E73A5B174EF4BE80B-8021
1 Fault Found:
009766 - Linear Oxygen (Lambda) Sensor B1 S1 Pump Current Trim Circuit
P2626 - 008 - Open - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 2
Fault Frequency: 32
Reset counter: 40
Mileage: 232086 km
Time Indication: 0
Date: 2017.07.01
Time: 13:24:30
Freeze Frame:
RPM: 1312 /min
Torque: 0.0 Nm
Text: 31.88
Text: -0.04 V
Voltage: 4.16 V
Text: 784 C
(no units): 108.0
Readiness: N/A
Thanks
Coding: 0000078
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 32
Reset counter: 40
Mileage: 232086 km
Time Indication: 0
Date: 2017.07.01
Time: 13:24:30
Freeze Frame:
RPM: 1312 /min
Torque: 0.0 Nm
Text: 31.88
Text: -0.04 V
Voltage: 4.16 V
Text: 784 C
(no units): 108.0
Readiness: N/A
Kahuna-Big
12-18-2009 06:23 PM
valentine1
11-13-2009 06:09 AM
