No windows by door key or remote
Hi Guys, I have a new /old A3 8pa 58 plate 2009 model year . It has an issue with the electric windows. first i noticed they will not lift or drop with the remote,I checked this with my vag com (NOT REGISTERED but fully open) and it showed , they were set to work. I tried to disable them and reset them ,but still no luck. I then tried to use the key in the door to lift or drop them,
and this also dose not work.... (This has got me stuck ,as iv had 4 audis and this has always worked) AND Yes the windows are set to lift and drop with one touch on the switches and that works fine..
1.I have tried to fit a new comfort unit (address 46 ) but this has not solved the issue.
2.i have checked wiring from door to body and can find no breaks.
3.one other issue is ,the indicator dose not flash to confirm locking and unlocking.
any helpfull input appreciated.
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 22 25 37 42 44 46 52 56 62 72 77
VIN: WAUZZZ8PX9A035720 Mileage: 188190km/116935miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BS HW: 03L 906 022 BQ
Component: R4 2.0l TDI G000SG 9978
Revision: 13H01--- Serial number: AUX7Z0H7FNI0EJ
Coding: 0000172
Shop #: WSC 61009 001 1048576
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 16426012492500FF681206E6921900823800
Shop #: WSC 18800 000 1048576
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH09 0100
Revision: vollauto Serial number: ppppnnnn123456
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008818293
Coding: 15A82F81B0141380EF00001C0000000000084E056401040300 2800000000
Shop #: WSC 06314 000 08192
Part No: 8P2 955 119 F
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Address 10: Park/Steer Assist (J446) Labels: None
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36861229201217
Coding: 000003
Shop #: WSC 19480 000 1048576
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142383038303030374A55305238503053
Shop #: WSC 06314 000 00000
ASAM Dataset: EV_Airba10AURB4 001001
ROD: N/A
No ASAM data for: "EV_Airba10AURB4" (AU35)
2 Faults Found:
9440027 - ROD - Unknown Error Code
9439771 - ROD - Unknown Error Code
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004042
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H18 0830
Revision: D0H18006 Serial number: 2247H006005453
Coding: 0005448
Shop #: WSC 55804 001 1048576
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K0882103E0
Coding: E9A27F064006021103
Shop #: WSC 19021 000 1048576
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D0H18006 Serial number: AUX7Z0H7FNI0EJ
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 S HW: 8P0 035 192 S
Component: RNS-E HIGH EU H77 0650
Revision: 04S Serial number: AUZBZ7H4115954
Coding: 0209757
Shop #: WSC 00067 210 75633
2 Faults Found:
02261 - Data Medium
014 - Defective - Intermittent
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000764
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 233 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 18802000025C3F298505481FC637
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
2 Faults Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication
01334 - Door Control Module; Rear Right (J398)
Address 52: Door Elect, Pass. Labels: Redir Fail!
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000764
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209757
2 Faults Found:
02261 - Data Medium
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000216
Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000216
1 Fault Found:
00099 - Right Rear Central Locking (Safe) Motor (V164)
012 - Electrical Fault in Circuit
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 N HW: 8P0 862 335 N
Component: FSE_256x BT H34 0520
Revision: 00000000 Serial number: 00000005029194
Coding: 0011422
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
End ---------------------------------------------------------------------
Chassis Type: 1K0
Coding: 0000172
Revision: 00H35001
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
Coding: 000003
ROD: N/A
2 Faults Found:
Coding: 0004042
Coding: 0005448
1 Fault Found:
011 - Open Circuit
Coding: 0000005
Coding: 0209757
2 Faults Found:
02261 - Data Medium
Coding: 0000764
Revision: 00H15000
2 Faults Found:
Coding: 0000764
Coding: 0209757
2 Faults Found:
02261 - Data Medium
Coding: 0000216
Coding: 0000216
1 Fault Found:
Coding: 0011422
1 Fault Found:
01304 - Radio
Lucasrocca (10-15-2021)
hi, I have some problems with my 2010 A3 and I suspect the comfort module too and I don't know where it is located on the car, can you please let me know its location, thanks in advance
tengo el mismo inconveniente en cuanto al fallo de airbag no se como solucionarlo!!!!
Chassis Type: 1K0
Coding: 0000172
Revision: 00H35001
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
Coding: 000003
ROD: N/A
2 Faults Found:
Coding: 0004042
Coding: 0005448
1 Fault Found:
011 - Open Circuit
Coding: 0000005
Coding: 0209757
2 Faults Found:
02261 - Data Medium
Coding: 0000764
Revision: 00H15000
2 Faults Found:
Coding: 0000764
Coding: 0209757
2 Faults Found:
02261 - Data Medium
Coding: 0000216
Coding: 0000216
1 Fault Found:
Coding: 0011422
1 Fault Found:
01304 - Radio
Chassis Type: 1K0
Coding: 0000172
Revision: 00H35001
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
Coding: 000003
ROD: N/A
2 Faults Found:
Coding: 0004042
Coding: 0005448
1 Fault Found:
011 - Open Circuit
Coding: 0000005
Coding: 0209757
2 Faults Found:
02261 - Data Medium
Coding: 0000764
Revision: 00H15000
2 Faults Found:
Coding: 0000764
Coding: 0209757
2 Faults Found:
02261 - Data Medium
Coding: 0000216
Coding: 0000216
1 Fault Found:
Coding: 0011422
1 Fault Found:
01304 - Radio
espero tu respuesta, muchas gracias y un saludo Lucas
CO AVANT
VAG-COM Discussion
06-17-2005 11:32 AM
Windows,, Are they suppose to go up with the key in the door like they go down when you turn the key
drewzin
Audi Original "S" Cars
06-19-2004 05:56 PM
BSCA4
08-14-2003 01:25 PM
Larry H
11-18-1998 05:07 AM
