Audi A3 / S3 / RS 3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
Tilt angle sensor and Abs no codes
Old 06-05-2017, 10:03 AM
the_horrorist's Avatar
Default Tilt angle sensor and Abs no codes
Hey all, I recently had my 09 a3 brought in to the dealer to have the ABS recall as well as my 65k service. The updates went well, but when the tech removed my horn he noticed some wires disconnected and a spring missing. They completed the updates but left the wires disconnected. I now have the ABS sensor and Tilt Angle sensor light on my dash. I have a cheap Vagcom reader which does not pull up any error codes. The dealership quoted me around 1400 for the part (I believe a clockspring or possibly the whole airbag/horn with springs). I had purchased this car used and the horn never worked properly it needed a good amount of force in the right area in order to work. I was told if the wires were connected the horn would not stop sounding.
So what I gather from all this is I was sold a vehicle with a rigged horn because the missing spring would cause the horn to go off endlessly and my horn currently functions via some disconnected wires that are pressure sensitive.
If the issue is really just a measly spring id hate to dish out 1400 in order to replace the entire part any advice is much appreciated!
Attached Thumbnails Tilt angle sensor and Abs no codes-img_2516.jpg   Tilt angle sensor and Abs no codes-img_2517.jpg
MarksA8L
27
07-03-2019 06:17 AM
VorsprungTT
12-11-2007 03:43 AM
Hibiscus Red S4
08-11-2006 03:58 PM
a4avant99
10-06-2005 06:28 PM
marcodant
10-28-2004 03:03 PM
Quick Reply: Tilt angle sensor and Abs no codes
