2014 A5, 2.0, Coolant reservoir overflow hose...
Mine was leaking at where it connects to the radiator. Audi tech tried to tell me the radiator was non-OEM so radiator might need replacing. I told him to 1st try to replace the $30 hose before the $1000 radiator and of course, that did the trick. However, I noticed he filled the reservoir up to the top, well past the MAX line. Does anyone know if that is going to be an issue? Seems every time (literally) I go to the dealership they screw something up.
Originally Posted by Greg Burch
(Post 25263044)
Check it when the engine is stone cold. If its over the Max line, syphon the excess out. I would think the worst that could happen is your reservoir would overflow potentially dumping the excess on any paint under the reservoir and antifreeze and paint are not a good combination. Who is your dealer if you care to share? John |
My solution
I bought a turkey baster and sucked out enough to get the level right at Max. Dealership is Audi Dominion in San Antonio, TX Thx for the reply! |
You are most welcome. That’s what we’re here for. |
