A5 front lower control arm & rearward lower control arm ball joint
Hello
I currently have a 2009 Audi A5 and have changed the front wheel bearing today, everything has gone fine until I tried to get the rear bolt through the front lower control arm, I can get the bolt through but the bush/arm and the mount are slightly misaligned and I cant seem to get it that extra few mm, the bolt is tapered but not sure if tapping with a hammer will align it, any tips/ideas what to try?
With the rearward lower control arm ball joint I just cant get the taper through far enough to get the nut on, again any tips/ideas would be greatly appreciated, I took today off in the hope I could get it done and back at work tomorrow, so ideally I would like to get it back on the road tonight.
It is on axle stands currently on my drive, don't have a lift or anything like that either.
Thanks in advance for any help or advice.
TT
TT
nadrealista
09-04-2007 06:38 AM
lkl2001
07-26-2004 02:54 PM
xdriver
06-24-2004 05:08 PM
[Arawan]
10-14-2003 07:48 AM
