Airbag light and fault codes
I bought an Audi A5 with a salvage title that I'm fixing. The airbags did not deploy but the Airbag light is on and I have the following fault codes. Any ideas what I need to do to clear the codes for good? When I clear them the codes come back right away.
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 Q HW: 8K0 959 655 Q
Component: AirbagVW-AU10 H51 0812
Serial number: 003NDD134KWQ
Coding: 30414333483038313130554A304C38543053
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 4B9F4D5CE201891270-801E
Crash sensor for side airbag: driver side:
Serial number: 6334MSME505D2C77O
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME506C2632A
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME655341708
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME0E5010705
2 Faults Found:
9443859 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 61876 km
Date: 2018.09.27
Time: 11:47:32
9444115 - Front Passenger's Front Airbag Crash Sensor
B101B 15 [137] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 61876 km
Date: 2018.09.27
Time: 11:47:32
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 61876 km
Date: 2018.09.27
Time: 11:47:32
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 61876 km
Date: 2018.09.27
Time: 11:47:32
Same issue with crash sensors not being able to clear codes
Hello, just saw your post. I have same exact issues. Same exact codes.. how did you fix it? If you don’t mind me asking you. Thank you.
Originally Posted by Dimas;[url
25358835[/url]]Hello, just saw your post. I have same exact issues. Same exact codes.. how did you fix it? If you don’t mind me asking you. Thank you.
hancash
06-18-2022 02:04 PM
BlackR1ce
03-22-2016 07:55 AM
