Active Steering Basic Settings needed
I swapped out our original J527 (no ALA, regular CCS) yesterday, but the salvage part returns a "Mechanical Failure" fault code for the steering angle sensor, though the live data in Address 16 for the sensor seems to look OK (except for the fact that the clockspring wheel appears to be rotated one turn CCW from zero-degrees), noted here: https://www.audiworld.com/forums/a4-.../#post26041039
I'm tempted to pull the module out to give the clockspring wheel a full turn CW and see if it can be calibrated, except for that "mechanical failure" fault code. --g
