UK: 2010 Audi A5 (Diesel) - Wont start after Fuel Pump Pressure Regulator replacement
My car was extremely low on fuel. After a short stop then start, I noticed the car was shaking at idle. I needed to fill up in which I did. Car was still shaking. I bought a cheap scan tool off Amazon and got code 05175. The web said to replace something called "Fuel Pump Pressure Regulator". See red circle in image; only held by two screws.
I replaced the old with new. Car started for few seconds then shuts off. I tried starting but it never seems to start. Switched back to old, can wont start. I head I need to "bleed" or remove trapped air. How to do this? Do I need the VCDS scan tool as in https://cimg3.ibsrv.net/gimg/www.aud...36e963b175.jpg |
Originally Posted by SpeedyA5
(Post 25211162)
I replaced the old with new. Car started for few seconds then shuts off. I tried starting but it never seems to start. Switched back to old, can wont start. I head I need to "bleed" or remove trapped air. How to do this? Do I need the VCDS scan tool as in this video? https://cimg3.ibsrv.net/gimg/www.aud...36e963b175.jpg |
No, sorry. I wasnt in the country so it was left at home for 4 months. It's now in the garage for 2 weeks and they cannot find the issue 🤔So far they have replaced 3 fuel injectors that were leaking but car still wont start. Once fixed. I'll update.
Hi Speedy Did you manage to get the problem fixed? any update of what was wrong ? having the same issue.
I have the same problem
(Post 25211162)
Audi fuel pump regulator
Hi I’m having exact issues, replaced switch and started then cut out and can’t get going again, wondering did you get to the bottom of the problem? |
