Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
New winter tires
Old 11-26-2012, 05:34 AM
sh00t3r's Avatar
Default New winter tires
Got the winter threads put on last week. 18" Blizzaks with rims from tirerack. The ride is amazing. Not as much road noise as I thought there would be. With less rubber on the road its easier to steer the car. Bumps and potholes are also less dramatic. Couple days later we got hit with a dusting of snow, not enough to test out the tire capabilities, but enough for me to see that these tires have a ton of grip. I don't say this often, but I can't wait for a good snowfall!
Old 11-26-2012, 06:30 AM
ChipB's Avatar
Quattro in the snow with a good set of winter tires is fantastic. You'll have fun slaloming around all the SUVs with all-season tires!
Old 11-27-2012, 04:52 AM
bilbo47's Avatar
I'm stoked too! Enkei Raijin (18x8) w/ Michelin Pilot Alpin PA4s.
Hrmmm.. the tire looks a little under-inflated in that pic, which begs the question.. What pressure should I be going for? Max on the tire is 51psi. I think [very cold] they are around 35psi now. Should I use the same cold pressure from the door sill?
Old 11-27-2012, 07:24 AM
ChipB's Avatar
Yes, follow the pressure recommendations on the door sill. And just to confirm - since you have 18" rims the tire size is 245/40R18, correct?
Old 11-27-2012, 07:37 AM
sh00t3r's Avatar
Those Enkei's look fantastic.
Old 11-28-2012, 04:19 AM
bilbo47's Avatar
Correct on the tire size. As for the rims, TireRack does not list them on the site, but lists all kinds of other Enkei rims with the same size/offset. 18x8 +35mm Sure enough, the Raijin's fit fine.
Yeah, I'm going to spend some quality time with my bike pump and tire pressure gauge this morning before work.
Old 12-01-2012, 08:55 PM
ragazzi_07's Avatar
Nice set up, did u purschase it from simply tire in Toronto?
Old 12-02-2012, 09:13 AM
bilbo47's Avatar
No. Rims from JRP in Mississauga (QEW&Winston Churchill), tires from Jensen Tire (roughly same area in Oakville).
Old 12-02-2012, 02:12 PM
ragazzi_07's Avatar
Thanks bilbo.
I noticed you have the awe installed as well. As far as I know Pfaff Tuning is the only local dealer around town that sells the kits.
How does it sound. Any drone
Old 12-04-2012, 03:29 AM
bilbo47's Avatar
Thanks bilbo.
No, not really. There is one sweet spot for bass/vibrations that might irritate someone, but certainly not me. The sweet spot is 100 to 120Km/h in 6th or basically the 2700-3000 rpm band. As I've said in other posts, turn up the radio a bit and the exhaust note gets drowned out.
Other than that, I'm happy with it.
slk928
15
12-15-2014 03:26 PM
spagolli94
RS4 (B7 Platform) Discussion
12-18-2010 02:50 PM
binzokun
Q5/SQ5 MKI (8R) Discussion
42
12-25-2009 07:15 AM
OMarqs
9
12-09-2007 05:26 PM
MTG 604
9
05-23-2002 08:16 AM
Quick Reply: New winter tires
