95 Cabriolet Power Window Issues.
Just purchased 95 Cabriolet. The divers window would not operate. I had found online a possible fix that worked. I can share the link if someone would like to check it out. Had to do with a power window control relay marked 367 under the dash to the left of the steering column. And a faulty solder joint. I didn't have much expectation of this working. But I pulled out the relay module, popped the cover off, and looked at the solder joints. everything look good. I was thinking this was not likely a problem. Then I found one joint that was cracked when I viewed it under magnification. Re soldered it and put back together and bingo it worked. Since then the passenger side window will go up but not go down with the passenger side switch. Will go up and down with the central switch on the middle console. And intermittently has issues when using the drivers side switch. That part seems to come and go. I am thinking it might be the wires at the flex point by the door hinge? Or maybe another solder joint in the control relay? I removed the passenger side switch and checked it with a meter and it tested good. Anyone have any suggestions? Thanks
overn06
01-17-2016 06:12 PM
MonSoonHell
09-15-2015 07:14 PM
Vrrooom
09-08-2015 03:06 PM
stormchaser1967
09-02-2015 09:26 AM
stormchaser1967
New Member Welcome Area
09-01-2015 01:29 PM
