Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
A5 Oil Change DIY Procedure - 3.2L Engine
Old 01-23-2010, 04:35 PM
  #11
schreckster's Avatar
Thanks for the huge amount of help. There just are not any sites for changing oil for Audi's. I dont know about you guys (or gals), but I cant afford to take my Q5 in every time, for simple maintenance like this. Again thanks for the help!
Old 08-01-2010, 12:13 PM
  #12
lilrussiankid406's Avatar
Default got a question
i changed my oil and it says warning change oil imidiatly.. its full tough, no leaks under the car
Old 05-04-2015, 09:48 AM
  #13
dliscomb's Avatar
... an O-ring on the lower body of the filter housing ...
Where is this one? I found the thicker of the two rubber rings (the one with the tab) in the cap, but I don't see the other one.
Many thanks!
Old 04-25-2016, 01:37 PM
  #14
mbchurch's Avatar
Thanks, found this helpful today changing the oil in my 08 Quattro, which has the 3.2 V6, it was a little tricky but all went well.
Old 08-13-2017, 03:54 PM
  #15
aware's Avatar
Default Thin o-ring for 3.2 engine and torque specs for oil change
Many thanks!
The thinner one is on the engine still, on the part (a cylinder) that the oil filter housing screws down over. Get a flashlight; you will see a small, thin o-ring that wraps around it. Use a real small (almost midget) screwdriver or hook to remove the old one and oil the new gasket very lightly.
Torque oil filter housing or cover to 25Nm. I used a 36mm socket that I had for axle nuts. VERY nice!
Oil Drain Plug is torqued to 22 ft. lb. Always use a new (aluminum) washer.
Ben
Old 08-14-2017, 05:12 AM
  #16
jschrauwen's Avatar
Location: Frankford, Ontario, Canada. 08 R8TT, 08 A5, 90 TT 300ZX, Ducati TT2
Nice write-up. Thank you.
Old 08-14-2017, 06:35 AM
  #17
dliscomb's Avatar
Originally Posted by aware
Ben
Hey, thanks for taking the time to answer my question!
I did find the ring eventually, and the torque specs are handy.
Kind regards,
Drew
smith2010Q7
Q7 MK 1 Discussion
37
03-09-2019 09:50 PM
m1964
Q5/SQ5 MKI (8R) Discussion
03-06-2010 11:25 AM
b.searcy
Audi 100 / A6 (C4 Platform)
04-03-2006 11:50 PM
zenithentropy
9
11-28-2003 03:59 PM
dA4banger.au
11
02-20-2003 06:31 PM
Quick Reply: A5 Oil Change DIY Procedure - 3.2L Engine
