Body Flex Creaking?
Body Flex Creaking?
Recently I have noticed when I go in or out of a driveway at an angle my car really creaks from the body flex.Does not seem normal but my dealer says the other RS5's that he has driven does the same.Any thoughts if this is normal or what could be the cause?.I have heard some S5's have the same issue....Thanks
Not sure if it's the same issue, but this user on AZ found a fix action:
http://www.audizine.com/forum/showth...ttling-Craking
I tried to lunricate those rubber stops and even put felt on them but it did not work.Hard to believe those rubber pieces are the cause to all the body flexing creaking that I get.My craeking is not just coming from the trunk area....
Nobody else has tis issue at all?
Sorry to be a nudge but nobody on this forum with a S5 or Rs5 has any type of body creaking when the go up there driveway at an angle.If so, please speak up so I know that I mught have an issue and need to get my car to the dealer to complain...Thanks..
I think it's highly unlikely that the body itself is creaking. More likely, it's some plastic interior piece, the rear seats, the sunroof assembly, bump stops in the trunk, etc.
And here I thought I was crazy. My A5 is three weeks mine tomorrow, and whenever i turn into a driveway or into the local strip mall where there is an elevation change, I have creaking noises. Haven't spent any serious listening time or tried to locate them, but I will. Read the article about the boot stops, will check.
But yeah, mine creaks...
John
John
possible rear seat hinge pins against plastic sleeve?
This is what my creaking/squeaking was in my A6, and how I solved it (lube the pin and sleeve). See this post with pic:
https://www.audiworld.com/forums/sho....php?t=2842361
Really have nothing to lose to see if A5's do the same. Just throwing it out there.
Update: had to run out for coffee supplies this evening (elixir of life and all that..), and the creak is definitely coming from the rear end somewhere. Could be those boot bumpers, or the seat hinge pins, I'll try folding down the seats tomorrow or the next day. Frustrating this is, indeed. Will keep y'all posted.
John M.
John M.
I tried to lubricate the boot bumpers but to no avail.To me it really is the body flex that is causing that creak and it is a pretty substanial creak not just a small rattle.
