Drive Select; setting does not retain
Hello Audi Forume Friends.
I have a question regarding to the setting of the Drive Select on my 14 S5.
Is it normal for the selected drive mode (Dynamic or Individual) returns to factory default setting after turned off the engine?
On my car, the selected driving mode (dynamic or individual or others) does not retain after the engine is turned off. I just test drove the 2017 A4 and noticed that the drive select setting is retained as the engine turned off.
Those who have the 2014 Audi; do you see the same issue as mine?
Thanks.
Nghia Ho
Thanks.
Nghia Ho
You are the second person reporting that their 2014 is not retaining the last drive select mode. Now I'm starting to think there might be a bug in some 2014. Starting with model year 2013, it should retain the last drive select mode by key fob along with the Individual settings and then when the same key fob is used again it should restore the previous settings along with climate control and seat position. The other person that reported this has a tune, though, so it's possible the bug is in the tune. Are you tuned or did you make some vagcom mods?
Civuck
Audi A3 / S3 / RS 3 MKII
15
12-09-2016 03:06 PM
BlownHeadlight
04-01-2004 03:10 PM
