fault code 03123
fault code 03123
Hello
In connection with the replacement of internal lighting lights, short connection between + and -, since all internal lighting and signal horns did not work, I checked all fuses that are ok. I got the wrong code (03123 pin 30-2 open circuit).
please someone who can help me how can i find the solution?
Hello
I have currently the same issue...
Can you tell me what was the problem and how you repaired it ?
Thank you !
OP isn't complete with his error code, the post is also from 6 years ago. But most likely you have a blown fuse for the J519 BCM.
Bob 2KS4
10-18-2022 11:16 PM
CrazyTT
VAG-COM Discussion
09-06-2006 06:04 AM
