How long is the Backup camera supposed to stay on?
Something annoying is going on with my brand new A5.
When in reverse, the backup camera comes on. When going back to drive-- it stays on! For at least 10 or 15 seconds it seems I am driving while seeing what is behind me on the MMI screen. I don't think this is the way it worked the first time I tried it- leading me to believe there is some setting I changed. Is this normal behavior or is there a way to make it turn off when I am in drive? Thanks! |
This is normal.
Originally Posted by jimmyn
(Post 23869904)
This is normal.
Other backup cameras I have had switch immediately when going into drive. Also, I haven't had a chance to try out the parallel parking mode on the parking camera. Do people find this actually works or is easy to use? Thanks again! |
You can change this setting by going mmi, car, setup.
Until you are going 9mph - the mirror also stays tilted down until 9mph
The purpose for it staying on is so that you can still use it to fine-tune your positioning, even if you are going into forward gear to pull up a bit.
Originally Posted by acadia
(Post 23869918)
Not sure if you are correct. I found a way to change the frequency of the "beeping" and the sensitivity of the backup radar, but couldn't find a way to change the time that the backup camera stays on while in drive. ANyone else have any luck? |
Originally Posted by Hobbes
(Post 23869941)
It also has the side benefit of letting you view whatever you just crushed/hit/banged... "Honey, what was that thump?" "I don't know dear, why don't you pull up a few inches and see what the TV screen shows..." |
The timing can be adjusted via Vagcom..
(Post 23869918)
