Interior LED Kit - $80 Shipped (Replace all your Interior bulbs)
#21
they are indeed slighty smaller
Appreciate your input but for some reason your the only customer i have had who finds the lights to be a bit smaller. They are a perfect replacement size and so far i have not had a similar complaint.
Based on what you told me though, it seems your bulbs may have been replaced with a bigger size, possibly from factory. Because like i said, you are the one and only who had this issue come up.
Question....does A&A also have replacement bulbs for the A5 fog lights? Those would be the last ones for me to swap out.
#22
Former Vendor
Highly unlikely that factory put in larger bulbs. Your bulbs fit nicely in the plate bracket lights but they don't snap in firmly, so due to the cylindrical design of the tips, they tend to "revolve" and the lighting side doesn't always point down on the plate. I'll fix it, but they are definitely slightly smaller than OEM and some of the other bulbs are just a little bigger. Results are well worth it but it does take some time to carefully do all bulbs.
Regarding the Fog Lights... yes i do have HID kits for your car. Their $90 Shipped. CANBUS Hid Kit... No errors or flickering. I also have them in 4300k which matches your DRL LED's perfectly.
#23
Audiworld Member
Ordered the A&A lights and am looking forward to them... hope I don't have any install issues, but I at least have a set of trim removal tools which should help.
BTW for fog lights you can also get the HOEN H11 Xenonmatch, which match the Xenons. A lot of people use them successfully and they're $30 plus shipping.
#24
Audiworld Member
Anyone else who's ordered this set have issues with the rear reading/map lights flickering?
I haven't put the dome and front reading lights in yet, but both rear reading lights pulse/flicker when turned on.
#26
Audiworld Member
BTW I had the same experience as tpt13 with the license plate festoons - they fit fine but the angle of the contacts must be slightly different than the stock lights. So they rotate a bit in place and flicker when the closing the trunk lid. No big deal, though, I will just secure them with a bit of electrical tape.
#27
Former Vendor
OK guys... for everyone who placed an order with me and their license plate led lights are not secure please PM or Email me... I will replace them free of charge for a slightly larger size. Also 6 LED Lights on each one...
#29
Former Vendor
#30
Audiworld Member
The bulbs are firmly seated in the connectors and they definitely work, so I am assuming the bulb warning has to do with not enough current or resistance being detected in the circuit. I know a few other people on other forums have run into this issue with some bulbs.
BTW thanks for helping fix this.
