Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
Key getting stuck in the ignition?
Old 01-30-2010, 09:27 AM
Default Key getting stuck in the ignition?
Anyone having their key getting stuck in the ignition when you turn off the car?
Has happened to me several times..
zub3qin is offline
Old 01-30-2010, 09:52 AM
I think there is a 1-2 second pause from when you turn the car off before it releases the key...is that what you're seeing - or does it stick longer?
u080570 is offline
Old 01-30-2010, 10:44 AM
yes, mine has done it twice. after a few tries i came out though. i do not know why
fandawg is offline
Old 01-30-2010, 01:32 PM
It's part of the design that there is a brief pause after shutoff before the key comes out. Don't know why, but that's the way they made it.
perdido34 is offline
Old 01-30-2010, 08:21 PM
When you push the key in, don't try to pull it right out, let it pop itself back out and then pull it out.
pudding is offline
Old 01-31-2010, 05:41 AM
Manual says: Give it 1-2 sec before you pull out. Or the locking mechanism will jam.
This wait does not apply to other types of...insertion.
Ryan1524 is offline
Old 01-31-2010, 06:35 AM
LOL
u080570 is offline
Old 01-31-2010, 05:30 PM
Longer....
It seems once I try and release it, it stays stuck for a long time. I jiggle it, press it in and out a few times... very scary.
zub3qin is offline
Old 01-31-2010, 08:58 PM
Once it is stuck they recommend you press it in again to let the locks re-engage and disengage properly. Don't people read manuals anymore these days.
Ryan1524 is offline
Old 02-01-2010, 06:02 AM
i usually use my index finger to press to shut off, then grab the key to pull it out - so two separate motions like that usually gives the car sufficient time to release the key.
works pretty similar to my bmw...
poker838 is offline
Quick Reply: Key getting stuck in the ignition?
