Need help with DRL issue
So this is my first Audi and I'm also new to forums but I'm obsessed with my car and would like to get into forums because I'm constantly fidgeting with my car. Anyway, I bought my car in the summer of 2017 and everything was completely normal but once it started to get colder (roughly when temps dropped below 40F) I started having an issue with one LED DRL. Sometimes when I would start the car in the morning a warning light would come on the dash after about a minute saying that the "Front right side marker light is out" and I'm not sure if that is what Audi calls DRL's but I would check and the passenger side DRL would be out but the low beam would be fine. But what has me confused is that it almost seems random because I can't seem to find out what is causing this. It doesn't happen in the summer so I figured the cold temperature was somehow causing it but some mornings it will be fine when its 20F and will go out later in the afternoon when its 30F. The only thing I have been able to do is restart the car and that will sometimes fix it but sometimes it will just go out again. Recently I've been thinking it has something to do with me starting the car and turning the seat warmers on and the rear window heater on right away and maybe that has something to do with it? Because like I said earlier, it doesn't happen in the summer and only comes around late fall/winter when I start using seat warmers and heaters. Any help would be appreciated and if you need more info or pictures I can get them. Thank you.
audi168
07-01-2002 02:10 PM
