Noobie needing some help with error codes
I picked up a 2009 S5 4.2L and I have couple kinks I would like to iron out. I about an OBDeleven and I am getting these error codes. My passenger door does not unlock unless I open it. Sometimes my door assist work and sometimes it does not. I noticed if I clear all the error codes it generally works until it gives errors again. I have bought the sensor for the passenger door because it said it was bad, just need to replace it. The radio and back up camera both work but I am getting an error code. The lane change assist I have not seen work at all. Finally one of my keys does not unlock the doors or anything but I noticed if it is in the car, the car will start. Any help and direction is appreciated, I have been lurking and researching but these codes I am having troubles with solving.
Car: Audi S5 Year: 2009 Body type: Coupe Engine: CAUB 260 kW (360 HP) 4.2 l Mileage: 166210 KM --------------------------------------------------------------- 6C Camera System Rear View System description: J772__Rearview Software number: 8T0907441B Software version: 0070 Hardware number: 4L0907441A Serial number: 525PA8-J84902E Coding: 1000008 Trouble codes: 02203 - Audio-/video input 1 Implausible signal Intermittent --------------------------------------------------------------- 0F Radio Tuner Digital System description: SDAR SIRIUS H07 Software number: 4E0910593M Software version: 0160 Hardware number: 4E0035593F Serial number: AUZ4Z7H0329598 Coding: 0000100 Trouble codes: 02635 - Tuner not enabled/activated static --------------------------------------------------------------- 05 Kessy System description: BCM2 1.1 Software number: 8K0907064AG Software version: 0134 Hardware number: 8K0907064AG Hardware version: H71 Long coding: 0F0000 Subsystems: System description: ELVAUDIB8 Software number: 8K0905852D Software version: 0039 Hardware version: H35 Serial number: 0208000021919001 Trouble codes: 03286 - Right front exterior door handle touch sensor Short circuit to ground static 00955 - Key 1 no or incorrect basic setting/adaptation static -------------------------------------------------------------- 19 Gateway System description: GW-BEM 5CAN-M Software number: 8T0907468L Software version: 0092 Hardware number: 8T0907468L Hardware version: H10 Serial number: 4400F084218259 Long coding: 000303 Subsystems: System description: J367-BDM Software number: 8K0915181B Software version: 0150 Hardware version: H04 Serial number: 1801FAC6140508 Trouble codes: 03041 - Energy management active Intermittent 01314 - Engine control module (ECM) No signal/communication Intermittent 01312 - Drive train data bus No signal/communication Intermittent |
As I mentioned in the A5 group on facebook, this has equally been covered in depth in past threads. I personally posted a bunch of links and info regarding door handle sensors, and door actuators.
The early years A4/A5 used a door handle sensor that has an orage-ish transparent plastic layer to it that eventually gets compromised by water over time. The revised door handle sensors are completely enclosed to correct this. They can be acquired off of ebay or AliExpress for dirt cheap. Something like over $100 each from dealership and about $15 to $20 each from Ebay or Aliexpress. I've been using the ebay door handle sensors for over 2 years without issues. I also acquired a driver's door lock actuator from AliExpress for less ten $50. |
https://www.audiworld.com/forums/aud...oblem-2882427/
https://www.audiworld.com/forums/aud...nlock-2941925/ This has everything you need for the door handle sensors. https://www.a5oc.com/forums/audi-a5-...ap-sensor.html Also refer to the Files Tab of the A/S/RS5 facebook group as I created an ample amount of data for the door handle sensors and door actuators. |
