Noobie needing some help with error codes
I picked up a 2009 S5 4.2L and I have couple kinks I would like to iron out. I about an OBDeleven and I am getting these error codes. My passenger door does not unlock unless I open it. Sometimes my door assist work and sometimes it does not. I noticed if I clear all the error codes it generally works until it gives errors again. I have bought the sensor for the passenger door because it said it was bad, just need to replace it. The radio and back up camera both work but I am getting an error code. The lane change assist I have not seen work at all. Finally one of my keys does not unlock the doors or anything but I noticed if it is in the car, the car will start. Any help and direction is appreciated, I have been lurking and researching but these codes I am having troubles with solving.
Car: Audi S5
Year: 2009
Body type: Coupe
Engine: CAUB 260 kW (360 HP) 4.2 l
Mileage: 166210 KM
6C Camera System Rear View
System description: J772__Rearview
Software number: 8T0907441B
Software version: 0070
Hardware number: 4L0907441A
Serial number: 525PA8-J84902E
Coding: 1000008
Trouble codes:
02203 - Audio-/video input 1 Implausible signal
Intermittent
0F Radio Tuner Digital
System description: SDAR SIRIUS H07
Software number: 4E0910593M
Software version: 0160
Hardware number: 4E0035593F
Serial number: AUZ4Z7H0329598
Coding: 0000100
Trouble codes:
02635 - Tuner not enabled/activated
static
05 Kessy
System description: BCM2 1.1
Software number: 8K0907064AG
Software version: 0134
Hardware number: 8K0907064AG
Hardware version: H71
Long coding: 0F0000
Subsystems:
System description: ELVAUDIB8
Software number: 8K0905852D
Software version: 0039
Hardware version: H35
Serial number: 0208000021919001
Trouble codes:
03286 - Right front exterior door handle touch sensor Short circuit to ground
static
00955 - Key 1 no or incorrect basic setting/adaptation
static
19 Gateway
System description: GW-BEM 5CAN-M
Software number: 8T0907468L
Software version: 0092
Hardware number: 8T0907468L
Hardware version: H10
Serial number: 4400F084218259
Long coding: 000303
Subsystems:
System description: J367-BDM
Software number: 8K0915181B
Software version: 0150
Hardware version: H04
Serial number: 1801FAC6140508
Trouble codes:
03041 - Energy management active
Intermittent
01314 - Engine control module (ECM) No signal/communication
Intermittent
01312 - Drive train data bus No signal/communication
Intermittent
Car: Audi S5
Year: 2009
Body type: Coupe
Mileage: 166210 KM
Coding: 1000008
Trouble codes:
Intermittent
Coding: 0000100
Trouble codes:
static
05 Kessy
Long coding: 0F0000
Subsystems:
Trouble codes:
static
static
19 Gateway
Long coding: 000303
Subsystems:
Trouble codes:
Intermittent
Intermittent
Intermittent
As I mentioned in the A5 group on facebook, this has equally been covered in depth in past threads. I personally posted a bunch of links and info regarding door handle sensors, and door actuators.
The early years A4/A5 used a door handle sensor that has an orage-ish transparent plastic layer to it that eventually gets compromised by water over time. The revised door handle sensors are completely enclosed to correct this. They can be acquired off of ebay or AliExpress for dirt cheap. Something like over $100 each from dealership and about $15 to $20 each from Ebay or Aliexpress.
I've been using the ebay door handle sensors for over 2 years without issues. I also acquired a driver's door lock actuator from AliExpress for less ten $50.
https://www.audiworld.com/forums/aud...oblem-2882427/
https://www.audiworld.com/forums/aud...nlock-2941925/
This has everything you need for the door handle sensors.
https://www.a5oc.com/forums/audi-a5-...ap-sensor.html
Also refer to the Files Tab of the A/S/RS5 facebook group as I created an ample amount of data for the door handle sensors and door actuators.
cameltrophyallroad
Audi allroad
05-05-2016 03:13 AM
TGABTG
A4 (B7 Platform) Discussion
11
10-04-2006 06:02 AM
2 good 2 be true
18
03-22-2004 05:09 PM
