Problems Coding B&O Amplifier replacement
Hello All.
Long time reader, first time poster.
I recently purchased a replacement B&O Amp for my 2008 S5 due to the reasonably common fault with bass and door speakers no longer working after window tinting. I have replaced a 8T0 035 223 M with a 8T0 035 223 T.
I've replaced the amp and attempted the Vcds coding however only the left speakers work at the moment. Adjusting Balance in the Sound setting has no effect at all.
Am I doing something wrong??? Any help appreciated,
Some more info.
After a scan these are the error codes
Monday,09,January,2012,18:48:12:31937
VCDS Version: Release 11.11.1
Address 47: Sound System Labels: 8T0-035-223-BOM.clb
Control Module Part Number: 8T0 035 223 T HW: 8T0 035 223 F
Component and/or Version: DSP Prem H14 0400
Software Coding: 020101
Work Shop Code: xxxx
VCID: xxxx
3 Faults Found:
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
Voltage: 13.90 V
Temperature: 16.0°C
Temperature: 18.0°C
Bin. Bits: 00000100
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
Voltage: 13.90 V
Temperature: 16.0°C
Temperature: 18.0°C
Bin. Bits: 00000100
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 73800 km
Time Indication: 0
Date: 2011.12.06
Time: 17:25:58
Freeze Frame:
Voltage: 10.60 V
Temperature: 21.0°C
Temperature: 22.0°C
Bin. Bits: 00000100
Bin. Bits: 00000001
Bin. Bits: 00000000
Any help would be greatly appreciated.
VCID: xxxx
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
Voltage: 13.90 V
Temperature: 16.0°C
Temperature: 18.0°C
Bin. Bits: 00000100
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
Voltage: 13.90 V
Temperature: 16.0°C
Temperature: 18.0°C
Bin. Bits: 00000100
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 73800 km
Time Indication: 0
Date: 2011.12.06
Time: 17:25:58
Freeze Frame:
Voltage: 10.60 V
Temperature: 21.0°C
Temperature: 22.0°C
Bin. Bits: 00000100
Bin. Bits: 00000001
Bin. Bits: 00000000
carl viking
36
04-27-2020 01:17 PM
CPLYONS
09-07-2015 07:19 PM
ECS Tuning-Audi
09-01-2015 12:25 PM
