Thinking about buying a 2013 or 2015 RS5...
#11
Good analysis SuperSwiss. I too looked up the relative final drive gear ratios and engine torque outputs. Peak torque loads at the he axle appear to be approx 17% higher on the RS with the input shaft and pinion rotating about 19% faster. Whether this justifies a 20000 mile service interval on the RS vs a life of the vehicle interval on the S is a job for the engineers. My instincts given the lower overal transmission ratios of a manual trans car like mine make me lean toward having a service done at my next engine service. (35000 mi). My 3,0 has not been tuned ( yet) but the temptation is real. I usually do my own services. I’ve serviced Haldex final drives on TTs many times but this will be new to me.
Has anybody done their own sport diff? I’ll be looking up a diy guide.
#12
https://www.audizine.com/forum/showt...r-differential)
#13
Servicing the rear differential is actually super easy. I have a writeup over on Audizine. You can use Motul Gear 300 on the mechanical MTF side and the only offering for the ATF side is Audi's fluid which is about $45 for a liter. You'll need one of each. Not sure if the S uses the same ATF side fluid as the RS. Best to check.
Darel Matthews
03-27-2018 02:36 AM
