Audi A5 / S5 / RS5 Coupe & Cabrio (B8) Discussion forum for the B8 Audi A5, S5 and RS5 Coupe and Cabriolet Model years 2009 - 2017
Transmission Mount Insert Question
Old 09-10-2018, 08:29 AM
GR4Y FOX's Avatar
Default Transmission Mount Insert Question
Hi,
I have a 2015 S5 (DSG transmission), and a 2014 SQ5. I’ve seen several people use a tans mount insert. What is the benefit to using it? Does it help with performance in any way?
Thanks,
Old 09-10-2018, 06:28 PM
Ape Factory's Avatar
It simply reduces the amount of movement when the transmission shifts. Theoretically the transfers more energy down the line. People report crisper shifting but personally, I'd do it in conjunction with the rear differential and subframe inserts. They'll make a noticeable difference as a package.
I don't know how you drive or if you do track days but the better your tires, the more difference these'll make. If it's a Sunday light cruiser, I'd say skip it.
I've installed all of them (transmission, subframe and the three differential bushings) and it does keep things tight. I went with the softer differential offerings, those that have polyurethane inserts as opposed to solid metal. For the subframe bushings, 034 Motorsports is the only one that makes them and they're solid. Got rid of a high speed side shimmy.
Old 09-10-2018, 06:50 PM
GR4Y FOX's Avatar
Thanks for the explanation!
a4_1.8t_01
04-03-2008 09:31 AM
S4gasm (LoTR)
9
08-13-2007 07:45 PM
EuroTrasher
04-10-2006 11:40 PM
choward
01-29-2002 08:25 AM
Quick Reply: Transmission Mount Insert Question
