Voice Recognition missing from menu
Just bought a 2015 S5. The Voice command button on the steering wheel does nothing when pressed. I went to MMI Setup and there is no "Voice Recognition" selection in the menu. All other commands are there (Language, Measurement Units, etc.). Seems bizarre that the command would simply be missing from the menu. My 2011 A5 VR command worked fine. Would very much appreciate any assistance in trouble shooting! Thanks in advance.
Enable through the obd port using a carista or vag comm unit. Lots of threads on the topic. Try a few searches..
Originally Posted by brookiez28
(Post 25338554)
Coupe or Cabrio? The latter has VR disabled from the factory due to the noise with the open roof interfering and making it perform poorly.
Originally Posted by JackInOhio
(Post 25338784)
Thanks much, superswiss. Going to get it dealt with tomorrow....
If you have a smart phone (and MMI), you might be able to do it with Carista - you'll save quite a few doallrs
UPDATE: Went to an Audi dealer today. They searched my VIN and said my car is not equipped with Voice Recognition . I was under the impression that ALL S5's come with VR but the convertibles have it disabled from the factory. Does anyone know the actual facts about this? I'm trying to determine if VR is merely disabled on my car or if it's impossible to set up because it does not have the VR option (if VR even IS an option). As mentioned in my original post, "Voice Recognition" does not even appear on the MMI Setup menu as an option but I am not sure if this means it's simply disabled and a knowledgable dealer can enable it, or if I'm SOL and there is no way to actually enable this feature. My car is a Premium Plus model. My 2011 A5 was also PP but had the VR feature. Thanks again for your help!
(Post 25339313)
I had the same problem the Carista worked great but once you enable will take few starts before it starts working. 14 rs5 vert
I had voice recognition in my 2017 S5 cab until they replaced the MMI controls and then it was gone. Taking it back in next week and plan on asking them to turn it back on.
