It’s the little things...
#112
I just found out that that it also works if you hit the start/stop button while in manual. Shifter will slide over.
#113
Hahaha...sorry for the repeat! I started reading this thread in July and forgot how it all got started!
#114
Am I missing something?
I tried to move ahead in my driveway 5 feet
started car a tried to pull ahead with door open car
won't move because parking brake on
is it not possible to move with open door?
#116
It does automatically set the parking brake if you’re in gear and you open the door, but I assume that you could release it manually.
#117
Another good feature I've discovered
when you get into car on a brutally hot daylike yesterday the climate control ramps up to bring up temperature to settings you've chosen
tap the the auto button and fan goes to max immediately blowing max cold air
when it cools off a bit tap again and right back to automatic mode setting
i find it very handy
#118
Okay so I just noticed this last night. When you unlock your car with the fob or by touching the door handle all sorts of lights turn on. Specifically the dome light for each seat turns on.
When you open the door the dome light for the seat/door you open stays on while the other three dim. It makes it highlight your seat like a siren luring you to come and sit. Whichever door you open it dims the other three.
It it just looks cool.
#119
The B9 A5 is spectacular at night!
