It’s the little things...
#122
#123
Club AutoUnion
How quickly map updates install from an SD Card! Took all of about 20 minutes to install the “2018 / 2019” update in the car.
Our Acura RDX Nav updates come on (2) DVDs and takes about 2 hours to get them installed - longer if you’re not paying attention to the first disc finishing and requesting the second DVD!
#124
#125
I just discovered over the weekend that while using cruise control, the control stalk can be bumped a little extra to cause gains or decreases in 5mph increments.
#126
As someone else pointed out, a soft bump is 1 mph, larger bump goes to next 5MPH setting (if it's 37, larger bump up goes to 40, soft bump up to 38)
#127
I might be crazy but I think the texture of the bottom of the floor mats are different for the driver mat vs. the other three. Driver mat seems more Velcro “grippy”.
#128
I noticed the same, when cleaning it you practically have to peel it off the floor not just lift it. And it is only the drivers mat that is like that. Great design detail :-)
#129
#130
If you have OBD11 or VCDS you can change to coding to enable it. There isn't an MMI option for this. I think some regions had it on by default but on my UK model I had to enable it. Really good for me as my driveway is on a slope forcing me to use the parking brake anyway. If it wasn't for that, I'd probably prefer to just leave the car in P only in most locations.
