12v cigarette outlets always on
#11
So let's go back to my original question & pretend my charger does what it's supposed to do. Does anyone know how to keep the keep the cigarette outlet live even after car is turned off?
#12
I assume you you have tried all of the adapters in the car?
Also on my NOCO the adapter when plugged in looks like it is all the way in, but isn’t.. just make sure to give a little nudge in case it isn’t making full contact... sorry I don’t have more for you..
#13
Per page 75 of the manual: "The sockets and the electrical accessories connected to them only function when the ignition is switched on."
#15
#16
#17
#18
https://www.audizine.com/forum/showt...it-s-always-on
#19
I have not tried this, and I don't know if there is any additional power switching between the cigarette outlet (socket) fuse and the socket itself. The theory being, take non accessory power in the fuse panel and jumper the power to the sockets. The jumper would have the fuse you removed for the socket inline with the jumper. I believe the fuse for the front socket is located in the panel to the left of the brake pedal.
THANK YOU! this is exactly what i was looking for!
#20
Audi S5 12vdc factory outlet should not be re-wired for constant 12vdc power.
I have a 2022 Audi S5, I have been a Systems Specialist for 20+ years. The cigarette12-VDC port in the front cab, does not have and cannot be configured for constant 12VDC power. You should not try to re-wire the factory outlet at the fuse box. I use a kit wired to the fuse box accessory/spare 15/20amp w/ constant12VDC. The kit has an inline fuse w/ usb-A, usb-C, and cigarette outlet that all supply constant 12VDC power. I paid $20 and it is worth it b/c the factory 12vdc port has heat shrinks and is permanently wired to the back of the fuse box grommet. Good Luck and Thanks.
GDawgA4
12-03-2007 02:45 PM
kk_1.8t
09-21-2002 05:42 AM
